    Really confused
    23 Posts 5 Posters 14.0k Views 4 Watching
      Duke86
      This post is deleted!
        doubleT Module Developer
        Ok, thanks for the private message. Seems like you have trouble posting the code. Don’t worry, we’ll sort it out the other way.
        You were able to open the config.js now delete the content completely! Copy the below code in the box and paste it into the config.js then save it.
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check-o ",
        						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "YOUR_OPENWEATHER_API_KEY"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
          Duke86
          ok thanks will try now
