    JQuery Draggable and UI Touch Punch
    4 Posts 2 Posters 3.3k Views 3 Watching
    • F
      faxe1008
      I want to build a module in which the user is able to move the elements over screen by dragging them with touch. To realise that I implemented this: http://touchpunch.furf.com/. It works perfectly fine in the browser (localhost:8080) but in the actual MagicMirror window it does not work at all.
      Anyone know how to fix that?
      • emloweE
        emlowe Module Developer
        I don’t know, but electron seems to have some issues with touch
        • https://github.com/electron/electron/issues/8725
        • https://github.com/electron/electron/issues/8125
        • https://stackoverflow.com/questions/40359462/electron-enable-touch-events-for-a-touch-screen
        I was thinking of trying to use the ZingTouch JS library to see it could be used to add some touch support easily
        -Earle
        • emloweE
          Also, you may find the hack of running node serveronly and then chrome in kiosk mode is ok for your use:
          node servonly
          and later start chromium in kiosk mode.
          chromium --noerrdialogs --kiosk 127.0.0.1:8080
          -Earle
          • F
            faxe1008
            I would rather of course prefer it working out of the box, but if I can not get it to work I will try this.
            I looked at the github issues and they are talking about the --enable-touch-events parameter of electron. I have not worked with electron before - do you know where to put that parameter inside the electron.js file?
            Ok, I tried it like this:
            const app = electron.app;
            app.commandLine.appendSwitch('--enable-touch-events');
            It does not do anything. How would I need to modify the magic mirror scripts in order for it to stop using electron and use chromium instead? I assume I would have to modify the run-start.sh script for that, (since you can not run bash through javascript). Can someone provide me some help for that?
