    SOLVED: Black screen after update. Problem with version of calendar module? Or something else?
    2 Posts 1 Posters 1.4k Views 1 Watching
    • K
      Klinge
      Hello,
      after installing an update I got a black screen. When I start my MM with
      npm start dev
      I get the following warning
      Starting MagicMirror: v2.2.2
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-WunderGround24Hours.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 54.
      App threw an error during load
          at Error (native)
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
          at Object.Module._extensions..node (module.js:583:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          at Function.Module._load (module.js:424:3)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
          at Error (native)
      Launching application.
      I tried some solution proposals, but unfortunately nothing helps.
      It would be great, if someone could help me.
      Thank you.
      • K
        Klinge
        The PIR-Module doesn’t work correctly.
        I got a tip to change in the module directory and enter npm install.
        I did it, the module was rebuild and so the MM works.
        Thank you.
