    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 299.3k Views 54 Watching
      andi.aw.weiss
      Hello everyone, I’m getting desperate. I’ve now read the entire tutorial but I can’t find my mistake.
      I am using my MM with a PIR sensor and would like to switch the backlight of the display with a relay. so i use this script pir.py:
      #!/usr/bin/env python
      import sys
      import time
      import RPi.GPIO as io
      import subprocess
      io.setmode(io.BCM)
      SHUTOFF_DELAY = 120 # in seconds, how long the monitor will be on until next button press or PIR detection
      PIR_PIN = 22       # 15 on the board (this needn't to be a PIR. Can be a button also)
      LED_PIN = 16      # optional
      def main():
          io.setup(PIR_PIN, io.IN)
          io.setup(LED_PIN, io.OUT)
          turned_off = False
          last_motion_time = time.time()
          while True:
              if io.input(PIR_PIN):
                  io.output(LED_PIN, io.LOW)
                  print ".",
                  sys.stdout.flush()
                  if turned_off:
                      turned_off = False
                      turn_on()
              else:
                  if not turned_off and time.time() > (last_motion_time +
                                                       SHUTOFF_DELAY):
                      turned_off = True
                      turn_off()
                  if not turned_off and time.time() > (last_motion_time + 1):
                      io.output(LED_PIN, io.HIGH)
              time.sleep(.1)
      def turn_on():
      	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
      def turn_off():
      	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
      if __name__ == '__main__':
          try:
              main()
          except KeyboardInterrupt:
              io.cleanup()
      Unfortunately, when I run this script in the terminal, I only get the feedback from the PIR sensor (…) but the relay is not switched. But if I run the monitor_on.sh or monitor_off.sh script it works:
      monitor_on.sh
      gpio -g mode 27 out
      sleep 0.2
      gpio -g write 27 1
      monitor_off.sh
      gpio -g mode 27 out
      sleep 0.2
      gpio -g write 27 0
      But the PIR.py doesn’t work. Where could the mistake lie?
      Many greetings Andreas
        MadScientist @andi.aw.weiss
        @andi-aw-weiss I think you are using the wrong script. With just a quick look it seems you’re running the script from point 2.2 (Using PIR script) of the first post. What you want is point 5.2 (Use relay with a PIR). That script used in 5.2 is different than that of 2.2, which does not have code to control the relay.
        Have a look at it again.
        A 2 Replies Last reply Reply Quote 0
          andi.aw.weiss @MadScientist
          @MadScientist Hey, unfortunately the problem hasn’t changed. I have now like you said the script from 5.2. The problem remains. PIR detects motion. Relay does not switch. :loudly_crying_face: I don’t know
            @MadScientist ok it seems to be working now. However, the relay switches the first time after the 120 s have expired and a movement is detected. not previously. The change quote: “io.output(RELAY_PIN, False)” and for monitor off “io.output(RELAY_PIN, True)” only causes the relay to work in reverse. I now use this script:
            import sys
            import time
            import subprocess
            io.setmode(io.BCM)
            LED_PIN = 17    # 11 on the board (optional): It just shows detection time of PIR without delay time
            RELAY_PIN = 27  # 13 on the board
            def main():
                io.setup(RELAY_PIN, io.OUT)
                turned_off = False
                while True:
                        print ("."),
                        sys.stdout.flush()
                        if turned_off:
                            turned_off = False
                            turn_on()
                    else:
                                                             SHUTOFF_DELAY):
                            turned_off = True
                            turn_off()
                    time.sleep(.1)
            def turn_on():
            def turn_off():
                try:
                    main()
                    io.cleanup()
            where could the error lie? or is that how it should be? Thank you MadScientist
            cruunnerrC M 2 Replies Last reply Reply Quote 0
            • cruunnerrC Offline
              cruunnerr @andi.aw.weiss
              @andi-aw-weiss
              Hey hey,
              So what exactly doesn’t work? My English isn’t the best
              In my case I am turning on a LED Stripe with the pir.
              When I cold start the raspi, the LED stripe turns on for a few seconds (could be the turnoff delay time).
              After a while it turns off.
              From this moment on it should work as you expect. When movement is detected, the led (or relay) turns on for the delay time and extend the delay time for every new movement within the original delay time.
                @andi-aw-weiss said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                Are you saying the screen turns off when the PIR detects a motion? In that case you have to change the the terminals on the relay. You have three terminals to connect the wires to. GND, normal open and normal close.
                Another note: I have a bunch of relays here that are supposed to be compatibles with Raspberry Pi’s but somehow they don’t properly work. They switch exactly once and then are stuck. Not sure if you’re having the same issues.
                  andi.aw.weiss @cruunnerr
                  @cruunnerr @MadScientist Thanks to both of you . For development/tutorial and support. My MM works. I was probably impatient the whole time I was testing. The relay only switches for the first time after the 120 s have expired. But that’s ok that it only occurs when you restart. I consider the problem solved. THANK YOU
                  • N Offline
                    nowayto
                    Hello, I know this is an old topic but I think it’s very interesting.
                    I have an idea but I’m a newbie to programming.
                    In my mind I was thinking about using one or more modules like these:
                    MMM-ModuleScheduler
                    MMM-Home-Presence
                    MMM-RemoteControl
                    to have a way to turning off the monitor when one member of the family is at home.
                    For “is at home” I mean when the phone is connected to wifi and the MMM-Home-Presence detect his presence.
                    Might be MMM-RemoteControl could communicate with MMM-Home-Presence and turn off/on the monitor?
                    What do you think about it?
                      sdetweil @nowayto
                      @nowayto you CAN compose a solution like that.
                      However Home-Presence does not inform other modules about state of devices
                      It could’ve extended to do that
                      Then you could config Remote-Controlto respond to that
                      • N Offline
                        nowayto @sdetweil
                        @sdetweil ok, I don’t think a newbie like me could do it but it was a good idea, if only Home-Presence had a notification option by default. Thanks
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 16 / 18
