    node_helper and python communication
    3 Posts 2 Posters 1.7k Views 2 Watching
      jmagsumbol
      I have started to dig in developing own modules. I wanted to use an ultrasonic sensor to check if a person is in front of the mirror minimum 100cm. In this case the python script sends a ‘message’ with a type event and distance in cm. This should turn off the screen. Then a timer (5sec) starts to switch off the screen again as long as there is no message coming in.
      I have several problems and don’t know why:
      1. the timer never starts
      2. my console logs are only displayed AFTER the magic mirror app is stopped.
      Can anyone give me a hint? Or is there a better implementation for the communication between python and the modules?
          python_start: function() {
          		pyshell = new PythonShell('serialDistance.py');
          		pyshell.on('message', function (message) {
          		  console.log(message);
          			self.switchScreenOn();
          switchScreenOff: function(){
          	console.log("Switch screen off");
          	clearInterval(timer);
          switchScreenOn: function(){
          	var self = this;
            console.log("Switch screens on");
          	timer = setInterval(self.switchScreenOff, 5000);
      • N Offline
        ninjabreadman @jmagsumbol
        @jmagsumbol Should the function be simply called start()? Does python_start() ever get called?
        Alternatively, with a slight modification of MMM-PIR-Sensor, I think this could all be done within Node.js. You’d just need to examine how to handle the GPIO of the ultrasonic sensor in however it differs from a PIR sensor.
        For actually turning the screen off and on, check out @cruunnerr‘s guide: https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/7
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
          jmagsumbol
          @ninjabreadman yap python_start is called by an event from the modules (script is not complete)
          In the MMM-PIR-Sensor the GPIO is used. In my case I would like to use usb. So i should require node-serial port. That’s what one way I can try it.
          But I also thought of doing the complete logic, like switching on/off the screen, in my python script. So the only job of the module is to call python.
