    Powering my mirror?
    45 Posts 6 Posters 37.6k Views 4 Watching
    • T Offline
      The Bean
      How do these look?
      http://s.aliexpress.com/67rmau6V?
      http://s.aliexpress.com/vuaEjyAR?
        MadScientist
        Yeah, that should do.
        • T Offline
          The Bean
          before i buy a power supply i wanted to ask if the one i had for it would work, if i spliced the adapter into it?
          https://www.ebay.com/itm/112168199465
            MadScientist
            Sure it works. I just proposed the other one because it’s very compact and I thought that was important. Use the once you already have to save costs as long as it suits you. It’s powerful enough if those values are correct.
            Especially those black power bricks can be of very bad quality. Run your mirror setup for a few hours and check that the power supply isn’t getting too hot.
            • T Offline
              The Bean
              My problem with it was that I didn’t want to have the brick of it out side the case. Or 3 foot of wire looped inside but I’ll have to cut it to add the step down anyway. So I may as well try it that way first. But I also didn’t know if it was big enough for both To run off of.
              • T Offline
                The Bean
                i ran into this problem awhile back but got put on the backburner.
                  maxbachmann
                  @The-Bean Whats the buck down converter? I guess the pi is just a to big load for it
                  Never expect those china buck down converters to achieve more than 50% of what they say they will do (especially without additional cooler)
                    maxbachmann
                    @The-Bean you might want to try with a additional cooler on the converter since the pi is not constantly pulling 2A, so it might work
                    • T Offline
                      The Bean
                      http://a.co/4qRQUQJ
                        maxbachmann
                        @The-Bean When it gets really hot I would try with a heatsink
                        and what happens when you connect it and then turn up the voltage until you reach 5V?
                        • 4 / 5
