    Powering my mirror?
    45 Posts 6 Posters 42.3k Views 4 Watching
    • T
      The Bean
      My point is that all the power supply’s under 80W only have one set of output wires.
        MadScientist
        Just use luster terminals.
        T 1 Reply Last reply
        • T
          The Bean @MadScientist
          @MadScientist sorry for so many questions. But won’t I need to solder them in a “T”? Or get a T splice?
            MadScientist
            Don’t be afraid to ask…
            Pic says more than a thousand words…
            alt text
            You can solder the wires together but that’s not really needed.
            • T
              @MadScientist ok awesome! That really did help I wasn’t thinking of doubling them up in the terminal.
              • T
                The Bean @The Bean
                https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191903753580
                This converter isn’t adjustable and it’s only 5.0 v would this work?
                  MadScientist
                  https://www.ebay.com/itm/1PCS-DC-DC-LM2596-power-Supply-Buck-Converter-step-down-module-NEW-CA/142147326064?hash=item2118a41070:g:L1kAAOSwvzRXzOBg
                  or
                  https://www.ebay.com/itm/DC-DC-Buck-Step-down-Regulator-Converter-4-2-23v-to-3V-3-3V-5V-9V-12V-24V-Module/112472493337?hash=item1a2fe20d19:g:dCsAAOSwdd9aVjD6
                  should do. They are adjustable via a potentiometer. Iam using the latter one for a Pi Zero but the 3A are enough to power a Pi3 easily. You should check aliexpress.com since most of the low priced parts already come from China. They will be even cheaper and are the very same product.
                  • T
                    The Bean
                    How do these look?
                    http://s.aliexpress.com/67rmau6V?
                    http://s.aliexpress.com/vuaEjyAR?
                      MadScientist
                      Yeah, that should do.
                      • T
                        The Bean
                        before i buy a power supply i wanted to ask if the one i had for it would work, if i spliced the adapter into it?
                        https://www.ebay.com/itm/112168199465
                          MadScientist
                          Sure it works. I just proposed the other one because it’s very compact and I thought that was important. Use the once you already have to save costs as long as it suits you. It’s powerful enough if those values are correct.
                          Especially those black power bricks can be of very bad quality. Run your mirror setup for a few hours and check that the power supply isn’t getting too hot.
                          • T
                            The Bean
                            My problem with it was that I didn’t want to have the brick of it out side the case. Or 3 foot of wire looped inside but I’ll have to cut it to add the step down anyway. So I may as well try it that way first. But I also didn’t know if it was big enough for both To run off of.
                            • T
                              The Bean
                              i ran into this problem awhile back but got put on the backburner.
                                maxbachmann
                                @The-Bean Whats the buck down converter? I guess the pi is just a to big load for it
                                Never expect those china buck down converters to achieve more than 50% of what they say they will do (especially without additional cooler)
                                  maxbachmann
                                  @The-Bean you might want to try with a additional cooler on the converter since the pi is not constantly pulling 2A, so it might work
                                  • T
                                    The Bean
                                    http://a.co/4qRQUQJ
                                      maxbachmann
                                      @The-Bean When it gets really hot I would try with a heatsink
                                      and what happens when you connect it and then turn up the voltage until you reach 5V?
                                      • T
                                        The Bean
                                        the converter its self doesnt really get hot.(that i have noticed) it just the wire to the pi. and once it drops, it doesnt adjust anymore.
                                          maxbachmann
                                          hm strange I mean I don’t know the cable size you use, but 5V 2A is pretty much nothing for any cable. Should not really get hot for sure
                                          • T
                                            The Bean
                                            thats what i thought… i will continue to investigate and post back if i find anything.
                                            • 2 / 3
