    Powering my mirror?
    45 Posts 6 Posters 41.2k Views 4 Watching
      MadScientist
      Yeah, I saw after I replied. I checked the datasheet and if I do not misunderstand the information, your screen should be at around 10W (max.). The board will probably take some, too. But you should be more than fine with a 30W power supply.
      • T Offline
        The Bean @MadScientist
        @MadScientist with the pi and all?
          MadScientist
          That should be enough for all if you don’t have more than the LCD, Raspberry Pi and the step-down module. You should check the power consumption of the LED strips, if you’re planning to use some. If not, you should be good with 30W.
          • T Offline
            @MadScientist
            Will both the LCD and the step down wire to the same wire? Will this lower the 12 volts from the lcd?
              MadScientist
              You split the 12V output of your power supply. One set of wires (plus and Gnd) goes to your LCD controller board (check polarity!) and one set to your step-down-converter, which is regulated to 5.1V for the Pi.
              • T Offline
                The Bean
                My point is that all the power supply’s under 80W only have one set of output wires.
                  MadScientist
                  Just use luster terminals.
                  • T Offline
                    @MadScientist sorry for so many questions. But won’t I need to solder them in a “T”? Or get a T splice?
                      MadScientist
                      Don’t be afraid to ask…
                      Pic says more than a thousand words…
                      alt text
                      You can solder the wires together but that’s not really needed.
                      • T Offline
                        @MadScientist ok awesome! That really did help I wasn’t thinking of doubling them up in the terminal.
                        • T Offline
                          The Bean @The Bean
                          https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191903753580
                          This converter isn’t adjustable and it’s only 5.0 v would this work?
                            MadScientist
                            https://www.ebay.com/itm/1PCS-DC-DC-LM2596-power-Supply-Buck-Converter-step-down-module-NEW-CA/142147326064?hash=item2118a41070:g:L1kAAOSwvzRXzOBg
                            or
                            https://www.ebay.com/itm/DC-DC-Buck-Step-down-Regulator-Converter-4-2-23v-to-3V-3-3V-5V-9V-12V-24V-Module/112472493337?hash=item1a2fe20d19:g:dCsAAOSwdd9aVjD6
                            should do. They are adjustable via a potentiometer. Iam using the latter one for a Pi Zero but the 3A are enough to power a Pi3 easily. You should check aliexpress.com since most of the low priced parts already come from China. They will be even cheaper and are the very same product.
                            • T Offline
                              The Bean
                              How do these look?
                              http://s.aliexpress.com/67rmau6V?
                              http://s.aliexpress.com/vuaEjyAR?
                                MadScientist
                                Yeah, that should do.
                                • T Offline
                                  The Bean
                                  before i buy a power supply i wanted to ask if the one i had for it would work, if i spliced the adapter into it?
                                  https://www.ebay.com/itm/112168199465
                                    MadScientist
                                    Sure it works. I just proposed the other one because it’s very compact and I thought that was important. Use the once you already have to save costs as long as it suits you. It’s powerful enough if those values are correct.
                                    Especially those black power bricks can be of very bad quality. Run your mirror setup for a few hours and check that the power supply isn’t getting too hot.
                                    • T Offline
                                      The Bean
                                      My problem with it was that I didn’t want to have the brick of it out side the case. Or 3 foot of wire looped inside but I’ll have to cut it to add the step down anyway. So I may as well try it that way first. But I also didn’t know if it was big enough for both To run off of.
                                      • T Offline
                                        The Bean
                                        i ran into this problem awhile back but got put on the backburner.
                                          maxbachmann
                                          @The-Bean Whats the buck down converter? I guess the pi is just a to big load for it
                                          Never expect those china buck down converters to achieve more than 50% of what they say they will do (especially without additional cooler)
                                            maxbachmann
                                            @The-Bean you might want to try with a additional cooler on the converter since the pi is not constantly pulling 2A, so it might work
                                            • 2 / 3
