    Powering my mirror?
    45 Posts 6 Posters 41.2k Views 4 Watching
    • T Offline
      The Bean @MadScientist
      @MadScientist it is the recommended power for the controller board https://rover.ebay.com/rover/0/e11400.m1842.l5919/7?euid=5138ba89bae64ecd98354e79c15592eb&bu=44095069551&loc=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fvod%3Ftransid%3D1755030964001%26itemid%3D112175476566%26qu%3D2&sojTags=bu=bu
      It’s an old laptop screen.
        MadScientist
        I can’t open that link because it links to your personal order details.
        Edit: If it’s a universal LCD controller board (like the V29, V56, or V59), then it also depends what LCD panel you’re using? Can you give me the panel number? Should be a sticker on the back of it. I’ll have a look at the datasheet.
        • T Offline
          @MadScientist I think this one should be good. I’m currently at work so I can’t just look at it.
          https://m.ebay.com/itm/LCD-Controller-Board-Driver-kit-for-LTN170WX-L08-HDMI-DVI-VGA-M-NT68676/112175476566?_mwBanner=1
            MadScientist
            Ah ok, I also of one of these to fire an old Laptop LCD for a digital picture frame.Now we need to know the type of the LCD. You can write it when you’re back home and I’ll look at it asap. Probably tomorrow since it’s already 7pm here.
            • T Offline
              @MadScientist will this be on the back of the screen it’s self?
                MadScientist
                Here’s an example from my LCD that I am going to use for my mirror
                alt text
                The M240HW01 V.D. is the LCD model and AU Optronics is the manufacturer.
                Btw, for the future: A V56 or V59 controller board are already available for less than 8€ incl. shipping and the firmware can be changed easily by USB. It has other disadvantages though, like not waking up automatically once the HDMI port is re-activated.
                • T Offline
                  @MadScientist wouldn’t that be the LTN170WX-L08 that i had to look up to find it? And thanks for the info on universal boards. Though I think I want the auto wake feature.
                    MadScientist
                    Yeah, I saw after I replied. I checked the datasheet and if I do not misunderstand the information, your screen should be at around 10W (max.). The board will probably take some, too. But you should be more than fine with a 30W power supply.
                    • T Offline
                      @MadScientist with the pi and all?
                        MadScientist
                        That should be enough for all if you don’t have more than the LCD, Raspberry Pi and the step-down module. You should check the power consumption of the LED strips, if you’re planning to use some. If not, you should be good with 30W.
                        • T Offline
                          @MadScientist
                          Will both the LCD and the step down wire to the same wire? Will this lower the 12 volts from the lcd?
                            MadScientist
                            You split the 12V output of your power supply. One set of wires (plus and Gnd) goes to your LCD controller board (check polarity!) and one set to your step-down-converter, which is regulated to 5.1V for the Pi.
                            • T Offline
                              The Bean
                              My point is that all the power supply’s under 80W only have one set of output wires.
                                MadScientist
                                Just use luster terminals.
                                • T Offline
                                  @MadScientist sorry for so many questions. But won’t I need to solder them in a “T”? Or get a T splice?
                                    MadScientist
                                    Don’t be afraid to ask…
                                    Pic says more than a thousand words…
                                    alt text
                                    You can solder the wires together but that’s not really needed.
                                    • T Offline
                                      @MadScientist ok awesome! That really did help I wasn’t thinking of doubling them up in the terminal.
                                      • T Offline
                                        The Bean @The Bean
                                        https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191903753580
                                        This converter isn’t adjustable and it’s only 5.0 v would this work?
                                          MadScientist
                                          https://www.ebay.com/itm/1PCS-DC-DC-LM2596-power-Supply-Buck-Converter-step-down-module-NEW-CA/142147326064?hash=item2118a41070:g:L1kAAOSwvzRXzOBg
                                          or
                                          https://www.ebay.com/itm/DC-DC-Buck-Step-down-Regulator-Converter-4-2-23v-to-3V-3-3V-5V-9V-12V-24V-Module/112472493337?hash=item1a2fe20d19:g:dCsAAOSwdd9aVjD6
                                          should do. They are adjustable via a potentiometer. Iam using the latter one for a Pi Zero but the 3A are enough to power a Pi3 easily. You should check aliexpress.com since most of the low priced parts already come from China. They will be even cheaper and are the very same product.
                                          • T Offline
                                            The Bean
                                            How do these look?
                                            http://s.aliexpress.com/67rmau6V?
                                            http://s.aliexpress.com/vuaEjyAR?
                                            • 2 / 3
