    Powering my mirror?
    45 Posts 6 Posters 42.3k Views 4 Watching
      MadScientist
      Ah ok, I also of one of these to fire an old Laptop LCD for a digital picture frame.Now we need to know the type of the LCD. You can write it when you’re back home and I’ll look at it asap. Probably tomorrow since it’s already 7pm here.
      • T
        The Bean @MadScientist
        @MadScientist will this be on the back of the screen it’s self?
          MadScientist
          Here’s an example from my LCD that I am going to use for my mirror
          alt text
          The M240HW01 V.D. is the LCD model and AU Optronics is the manufacturer.
          Btw, for the future: A V56 or V59 controller board are already available for less than 8€ incl. shipping and the firmware can be changed easily by USB. It has other disadvantages though, like not waking up automatically once the HDMI port is re-activated.
          • T
            @MadScientist wouldn’t that be the LTN170WX-L08 that i had to look up to find it? And thanks for the info on universal boards. Though I think I want the auto wake feature.
              MadScientist
              Yeah, I saw after I replied. I checked the datasheet and if I do not misunderstand the information, your screen should be at around 10W (max.). The board will probably take some, too. But you should be more than fine with a 30W power supply.
              • T
                @MadScientist with the pi and all?
                  MadScientist
                  That should be enough for all if you don’t have more than the LCD, Raspberry Pi and the step-down module. You should check the power consumption of the LED strips, if you’re planning to use some. If not, you should be good with 30W.
                  • T
                    @MadScientist
                    Will both the LCD and the step down wire to the same wire? Will this lower the 12 volts from the lcd?
                      MadScientist
                      You split the 12V output of your power supply. One set of wires (plus and Gnd) goes to your LCD controller board (check polarity!) and one set to your step-down-converter, which is regulated to 5.1V for the Pi.
                      • T
                        The Bean
                        My point is that all the power supply’s under 80W only have one set of output wires.
                          MadScientist
                          Just use luster terminals.
                          • T
                            @MadScientist sorry for so many questions. But won’t I need to solder them in a “T”? Or get a T splice?
                              MadScientist
                              Don’t be afraid to ask…
                              Pic says more than a thousand words…
                              alt text
                              You can solder the wires together but that’s not really needed.
                              • T
                                @MadScientist ok awesome! That really did help I wasn’t thinking of doubling them up in the terminal.
                                • T
                                  The Bean @The Bean
                                  https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191903753580
                                  This converter isn’t adjustable and it’s only 5.0 v would this work?
                                    MadScientist
                                    https://www.ebay.com/itm/1PCS-DC-DC-LM2596-power-Supply-Buck-Converter-step-down-module-NEW-CA/142147326064?hash=item2118a41070:g:L1kAAOSwvzRXzOBg
                                    or
                                    https://www.ebay.com/itm/DC-DC-Buck-Step-down-Regulator-Converter-4-2-23v-to-3V-3-3V-5V-9V-12V-24V-Module/112472493337?hash=item1a2fe20d19:g:dCsAAOSwdd9aVjD6
                                    should do. They are adjustable via a potentiometer. Iam using the latter one for a Pi Zero but the 3A are enough to power a Pi3 easily. You should check aliexpress.com since most of the low priced parts already come from China. They will be even cheaper and are the very same product.
                                    • T
                                      The Bean
                                      How do these look?
                                      http://s.aliexpress.com/67rmau6V?
                                      http://s.aliexpress.com/vuaEjyAR?
                                        MadScientist
                                        Yeah, that should do.
                                        • T
                                          The Bean
                                          before i buy a power supply i wanted to ask if the one i had for it would work, if i spliced the adapter into it?
                                          https://www.ebay.com/itm/112168199465
                                            MadScientist
                                            Sure it works. I just proposed the other one because it’s very compact and I thought that was important. Use the once you already have to save costs as long as it suits you. It’s powerful enough if those values are correct.
                                            Especially those black power bricks can be of very bad quality. Run your mirror setup for a few hours and check that the power supply isn’t getting too hot.
                                            • 2 / 3
