    Powering my mirror?
    45 Posts 6 Posters 41.0k Views 4 Watching
      MadScientist
      That should be enough for all if you don’t have more than the LCD, Raspberry Pi and the step-down module. You should check the power consumption of the LED strips, if you’re planning to use some. If not, you should be good with 30W.
      • T Offline
        The Bean @MadScientist
        @MadScientist
        Will both the LCD and the step down wire to the same wire? Will this lower the 12 volts from the lcd?
          MadScientist
          You split the 12V output of your power supply. One set of wires (plus and Gnd) goes to your LCD controller board (check polarity!) and one set to your step-down-converter, which is regulated to 5.1V for the Pi.
          • T Offline
            The Bean
            My point is that all the power supply’s under 80W only have one set of output wires.
              MadScientist
              Just use luster terminals.
              • T Offline
                @MadScientist sorry for so many questions. But won’t I need to solder them in a “T”? Or get a T splice?
                  MadScientist
                  Don’t be afraid to ask…
                  Pic says more than a thousand words…
                  alt text
                  You can solder the wires together but that’s not really needed.
                  • T Offline
                    @MadScientist ok awesome! That really did help I wasn’t thinking of doubling them up in the terminal.
                    • T Offline
                      The Bean @The Bean
                      https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191903753580
                      This converter isn’t adjustable and it’s only 5.0 v would this work?
                        MadScientist
                        https://www.ebay.com/itm/1PCS-DC-DC-LM2596-power-Supply-Buck-Converter-step-down-module-NEW-CA/142147326064?hash=item2118a41070:g:L1kAAOSwvzRXzOBg
                        or
                        https://www.ebay.com/itm/DC-DC-Buck-Step-down-Regulator-Converter-4-2-23v-to-3V-3-3V-5V-9V-12V-24V-Module/112472493337?hash=item1a2fe20d19:g:dCsAAOSwdd9aVjD6
                        should do. They are adjustable via a potentiometer. Iam using the latter one for a Pi Zero but the 3A are enough to power a Pi3 easily. You should check aliexpress.com since most of the low priced parts already come from China. They will be even cheaper and are the very same product.
                        • T Offline
                          The Bean
                          How do these look?
                          http://s.aliexpress.com/67rmau6V?
                          http://s.aliexpress.com/vuaEjyAR?
                            MadScientist
                            Yeah, that should do.
                            • T Offline
                              The Bean
                              before i buy a power supply i wanted to ask if the one i had for it would work, if i spliced the adapter into it?
                              https://www.ebay.com/itm/112168199465
                                MadScientist
                                Sure it works. I just proposed the other one because it’s very compact and I thought that was important. Use the once you already have to save costs as long as it suits you. It’s powerful enough if those values are correct.
                                Especially those black power bricks can be of very bad quality. Run your mirror setup for a few hours and check that the power supply isn’t getting too hot.
                                • T Offline
                                  The Bean
                                  My problem with it was that I didn’t want to have the brick of it out side the case. Or 3 foot of wire looped inside but I’ll have to cut it to add the step down anyway. So I may as well try it that way first. But I also didn’t know if it was big enough for both To run off of.
                                  • T Offline
                                    The Bean
                                    i ran into this problem awhile back but got put on the backburner.
                                      maxbachmann
                                      @The-Bean Whats the buck down converter? I guess the pi is just a to big load for it
                                      Never expect those china buck down converters to achieve more than 50% of what they say they will do (especially without additional cooler)
                                        maxbachmann
                                        @The-Bean you might want to try with a additional cooler on the converter since the pi is not constantly pulling 2A, so it might work
                                        • T Offline
                                          The Bean
                                          http://a.co/4qRQUQJ
                                            maxbachmann
                                            @The-Bean When it gets really hot I would try with a heatsink
                                            and what happens when you connect it and then turn up the voltage until you reach 5V?
                                            • 2 / 3
