    MMM-Hue
    huehome automation
    25 Posts 16 Posters 25.3k Views 17 Watching
      darrene @Mitchfarino
      Thanks @Mitchfarino - it was user-error. I visited the developer page rather than clicking on the link you provided :) I deleted my previous post in shame after I realised my error.
      All sorted now. It’s fabulous. Thanks for sharing your code with the community by the way!
        darrene
        Hi @Mitchfarino, I was just wondering if you’d considered extending the module to control lighting schedules?
        It suddenly struck me that as the mirror is always on and stays in the house, it might be very really cool (not to mention useful when you’re away) to have a capability in the module to turn on/off dim lights on a hardcoded schedule or time/day combo.
        From there it could even be a short hop to link it up the the MMM-RemoteControl module, to set schedules remotely.
        MitchfarinoM 1 Reply Last reply Reply Quote 0
        • MitchfarinoM Offline
          Mitchfarino Module Developer @darrene
          Hi @darrene
          Do you mean you want to be able to control the lights/schedules from your mirror?
          How would you interact with it to create them etc?
          I think at the moment the remote control only allows you show or hide modules, I’m not sure what future developments are in the pipeline though ( @Jopyth will know more on that)
            darrene
            Not directly - I think it’d be a lot of work and as you say, would need a way of interfacing with the mirror. At the end of all that you could just use The Hue/Elgato Eve/Siri app to do the same thing.
            What I wondered though, was if something like MMM-Schedule was installed, it’d be really easy to put a schedule in the config.js to turn specific lights on and off on certain schedules - it could send the notification schedule which MMM-Hue could react to. It’d mean you/the mirror could schedule the lighting schemes automatically to run while you were away from home.
            If MMM-Hue could react to a HUE_LIGHT_ON and HUE_LIGHT_OFF notification, perhaps with a light-ID and Brightness value as the payload, that’d do the trick wouldn’t it?
            A scheduling GUI would be uber-cool, but hard-coding the config.js would be enough for most, I’d have thought…
            It’s on my (very long) list of things to have a go at, if I get a chance :)
            • ClogsC Offline
              Clogs
              Hi @Mitchfarino
              Like your MMM-Hue module but will admit getting it to work was a little bit more tricky then what I had anticipated.
              My version 1.0 Hue hub setup controlling a 9 individual bulbs. I did not set up the bulbs as part of a groups.
              Wanted to share just a few simple findings to help others to get your module to work even better.
              Inspecting your code in MMM-Hue.js I found that you had a this.lightsorgroups hardcoded to “groups”. As a result of this my Hue setup was presented as just the Home icon with ‘Lights On’ as the status.
              Changing the hardcoded this.lightsorgroups to “lights” did result in a similar display as shown in your first post however all the named lights showed the X (fa-times) icon for the status even though lights were on, others off an others unreacheable.
              So I made a further minor change on line 69 and changed it to:
              lightstatus.classList.add("fa", this.result[lamps[i]].state.reachable ? (this.result[lamps[i]].state.on ? "fa-lightbulb-o" : "fa-adjust" ) : "fa-times");
              Keep up the good work.
                Mitchfarino Module Developer @Clogs
                Hi @Clogs
                Thanks for your feedback, I’m sorry I haven’t been able to update the module to account for individual lights
                As you have noticed it is in the code, I just didn’t expose it to the config.
                I’m going to pick it up soon, and will update in this thread.
                Thanks for letting me know, and for giving me the nudge I need to get it updated
                • tidus5T Offline
                  tidus5
                  Hello @Mitchfarino
                  Im trying to make your module “clickable” :-)
                  could you help me with that ?
                  Module.register(“MMM-Hue”, {
                  defaults: {
                      bridgeip: "",
                      userid: "",
                      colour: true
                  // Define required scripts.
                  getScripts: function () {
                      return [this.file("js/jquery.js")];
                  getStyles: function () {
                      return ["font-awesome.css", "MMM-Hue.css"];
                  // Define start sequence.
                  start: function () {
                      //These will be moved to config in a later release
                      this.lightsorgroups = "groups";
                      this.updateInterval = 60 * 100; // 10000 updates every 10 minutes
                      this.animationSpeed = 2 * 1000;
                      this.initialLoadDelay = 0;
                      //end
                      var result = false;
                      this.url = "http://" + this.config.bridgeip + "/api/" + this.config.userid + "/" + this.lightsorgroups;
                      this.getData();
                      setInterval(() => {
                          this.getData();
                      }, this.updateInterval);
                  // Override dom generator.
                  getDom: function () {
                      //alert("http://" + this.config.bridgeip + "/api/" + this.config.userid + "/" + this.config.lightsorgroups);
                      if (this.result) {
                          var table = document.createElement("table");
                          table.classList.add("small", "table", "align-left");
                          table.appendChild(this.createLabelRow());
                          var lamps = Object.keys(this.result);
                          for (var i = 0; i < lamps.length; i++) {
                              var row = document.createElement("tr");
                              var room = document.createElement("td");
                              room.innerHTML = this.result[lamps[i]].name;;
                              row.appendChild(room);
                              var lightsallLabel = document.createElement("td");
                              lightsallLabel.classList.add("centered");
                              var lightstatus = document.createElement("i");
                              //lightstatus.classList.add(“fa”, this.result[lamps[i]].state.reachable ? (this.result[lamps[i]].state.on ? “fa-lightbulb-o” : “fa-adjust” ) : “fa-times”);
                  	buttonlightstatus[i] = false;  // CUSTOM
                  	buttonlight[i] = document.createElement("span");  // CUSTOM
                  	//var buttonlightstatus[i] = false;  // CUSTOM
                  	//var buttonlight[i] = document.createElement("span");  // CUSTOM
                  	//weatherbutton.className = "wi wi-day-rain-mix navbar";
                  	//var forecast = MM.getModules().withClass('weatherforecast');
                  	if(this.result[lamps[i]].state.all_on)
                  	lightstatus.classList.add("fa-lightbulb-o")
                  	buttonlightstatus[i] = true;
                  	else if (this.result[lamps[i]].state.any_on)
                  	lightstatus.classList.add("fa-adjust")
                  	else {
                  	lightstatus.classList.add("fa-times")
                  	// lightstatus.classList.add("fa", this.result[lamps[i]].state.all_on ? "fa-lightbulb-o" : (this.result[lamps[i]].state.any_on ? "fa-adjust" : "fa-times"));  // CUSTOM
                              if (this.config.colour) {
                                  if (this.result[lamps[i]].state.all_on) {
                                      lightstatus.classList.add("lights-all-on")
                                  else {
                                      if (this.result[lamps[i]].state.any_on) {
                                          lightstatus.classList.add("lights-partial-on")
                              lightsallLabel.appendChild(lightstatus);
                      		wrapper.appendChild(buttonlight[i]);  //CUSTOM
                              row.appendChild(lightsallLabel);
                              table.appendChild(row);
                          wrapper.appendChild(table);
                         										//CUSTOM
                          		$(buttonlight[i]).on("click", function(){
                  					if(buttonlightstatus[i]){
                  					alert('its work');
                  					putJSON(t"http://" + this.config.bridgeip + "/api/" + this.config.userid + "/lights/" + buttonlightstatus[i] +"/state , ({'on':false});
                  					}else{
                  					putJSON(t"http://" + this.config.bridgeip + "/api/" + this.config.userid + "/lights/" + buttonlightstatus[i] +"/state , ({'on':true});
                      } else {
                          wrapper.innerHTML = "No Data returned";
                      return wrapper;
                  createLabelRow: function () {
                      var labelRow = document.createElement("tr");
                      var roomiconlabel = document.createElement("th");
                      var typeIcon = document.createElement("room");
                      typeIcon.classList.add("fa", "fa-home");
                      roomiconlabel.appendChild(typeIcon);
                      labelRow.appendChild(roomiconlabel);
                      var lightsonlabel = document.createElement("th");
                      lightsonlabel.classList.add("centered");
                      var typeIcon = document.createElement("lightson");
                      //typeIcon.classList.add("fa", "fa-lightbulb-o");
                      typeIcon.innerHTML = "Lights On";
                      lightsonlabel.appendChild(typeIcon);
                      labelRow.appendChild(lightsonlabel);
                      return labelRow;
                  getData: function () {
                      $.getJSON(this.url, (data) => {
                          this.result = data;
                          this.updateDom();
                  my brigde is in Amsterdam and im in Belgium for Christmas :-)
                    d3r
                    Would it be possible to display the wake up and sleep times of the bulbs/groups? Is that supported by the api?
                    I use my hue lights to wake me up in the morning. Some days I need to wake up at 5am others 6am. I find myself forgetting to change the wake up time in the app. If I could display the wake up time on my MM2, I would remember to change the wake up time which would be perfect.
                    • slametpsS Offline
                      slametps
                      @Mitchfarino : I did a pull-request for Indonesian translation and showLabel option to your MMM-Hue module.
                      regards,
                      Slamet PS
                      • schlachtkreuzer6S Offline
                        schlachtkreuzer6
                        hi!
                        show only when on does not work for me… any tip? thanks!
                        • 3 / 3
