Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    Calendar module width limit
    Bug Hunt
    • Y
      yomm last edited by
      Hello all !
      My installation is on a rpi3. My mirror/screen is a 20’ with a 1650*1050 resolution. MM² and modules are up to date.
      I use Calendar module for a while, his position on the mirror is top_left.
      Recently I add some other calendars with some long name meetings.
      I got a strange behavior : the calendar module expands from the left of the screen to the middle. This happens when long name event are schedule.
      I tried MyCalendar module which is based on Calendar. Same thing happens.
      So is there a way to limit the width of the calendar module to prevent it spreading on the half of the screen ?
      Thanks for your help !
      • N
        ninjabreadman @yomm last edited by ninjabreadman
        @yomm There are different regions, but most will expand to try to accommodate your content/text.
        See this post moments ago here, where I give advice on how to limit the width. In your case, I believe the selector is .module.calendar.
        You can also use the CSS word-wrap property to make your events break to the next line, or text-overflow to display an ellipsis when they’re cut off.
        • Y
          yomm last edited by yomm
          Thank you ninjjabreadman !
          Exactly what I need !
          .module.MMM-MyCalendar {
          max-width: 300px;
