    Anyone face problem with MMM-EmbedYoutube module
    6 Posts 3 Posters 2.9k Views 3 Watching
    • W Offline
      werdnllac
      I had followed the instruction and added the scripts as per follow:
      I edited config.js and added the script:
      		module: "MMM-EmbedYoutube", // Path to youtube module from modules folder Exmaple: MagicMirror/modules/custom/MMM-EmbedYoutube/ so it's custom/MMM-EmbedYoutube
      		position: "bottom_bar",	// This can be any of the regions.
      			video_id: "w3jLJU7DT5E"
      And created a directory as /MagicMirror/modules/custom/MMM-EmbedYoutube created the 3 files:
      1. MMM-EmbedYoutube.js
      2. license.txt (Although it is not necessary)
      3. README.md
      But the script don’t work at all despite many attempts. I have also tried edited “video_id: “w3jLJU7DT5E”” for the source of the video.
      Any thoughts?
      • P Offline
        pinsdorf Module Developer
        One thing which does not look right is the custom in your path. Moreover your path is in the root and not under /home/pi. It should read /home/pi/MagicMirror/modules/MMM-EmbedYoutube or ~/MagicMirror/modules/MMM-EmbedYoutube, which is equivalent for user pi.
        From your description I get the impression that you did not use the tool git to checkout the module into your modules directory. Is this possible? If so, please do the following:
        • cd ~/MagicMirror/modules
        • git clone https://github.com/nitpum/MMM-EmbedYoutube.git
        • Leave the config.js as it is, it looks good
        • Start your Magic Mirror
        • W Offline
          werdnllac
          Hi pinsdorf, thanks for your prompt reply. I manage the clone and it works now. Thanks
          • W Offline
            werdnllac
            This post is deleted!
            • W Offline
              werdnllac @werdnllac
                jchenaud
                hi ! thk for modul.
                i have just one problem : i need to make definition lower because my Pi go slowly with video how i am suppose to do ?
