    Help,please. iFrame wont display ANYTHING // Already read ALL other Threads regarding that
    iframetroubleshootmodule
    5 Posts 2 Posters 2.8k Views 2 Watching
      A Former User
      So as the Title may gave it away, I was trying to implement this MMM-iframe .
      But its not displaying anything. The URL was found in this Forum seemed to be working for others thats why I used it for testing.
      When I check the Console it keeps getting a GET Error on localhost:8080/(some random letter) like :" GET http://localhost:8080/t 404 (Not Found)"
      Sometimes its c instead of t etc.
      Openweather its throwing me GET errors too but works flawlessly as well as the Calender GET errors but working perfectly.
      Also tried running node server and checking browser, no luck.
      I’d appreciate any help
                              module: 'iFrame',
                              position: 'top_center',
                                      scrolling: "no",
                                      url: "http://service.mta.info/ServiceStatus/status.html?widget=yes",
                                      updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                                      width: "300px", // Optional. Default: 100%
                                      height: "100px", //Optional. Default: 100px
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Guest
        @LuiDavinci you have two main issues, first the module is MMM-iFrame and not iFrame, second the url has to be an array url: ["http://service.mta.info/ServiceStatus/status.html?widget=yes"], with those changes I can see it on my monitor.
        Furthermore, the documentation gives no details about a scrolling config option https://github.com/alberttwong/MMM-iFrame#configuration-options
          A Former User
          This post is deleted!
            A Former User @strawberry 3.141
            @strawberry-3.141 already tried both of those things, then I renamed the Module everywhere to iFrame… however after your Suggestions I changed everything back and tried it with an Array and MMM-iFrame… and still nothing… unfortunately
              A Former User
              Ok I “solved” it… I did the first freaking rule, I deleted the Module and reinstalled it, and now it works I didnt change anything in the config file… smh
              BTW: yes scrolling is an option, its not in the Docs but if you check the actual files you see that it is possible
