    Need more compliments? compliments.json
    Scheduled Pinned Locked Moved Fun & Games
    16 Posts 8 Posters 12.5k Views 8 Watching
      amanzimdwini @ryck
      @ryck
      I am struggling with this… why am I dense?
      1. IF I use
      remoteFile="https://gist.githubusercontent.com/ryck/..."
      (ie just pointing at YOUR file online), THEN things work. (but this is what I did not like in the first post of mine)
      1. IF I copy your compliments.json into ~/MagicMirror/modules/default/compliments/compliments.json
        like I read your response, and use
      remoteFile="compliments.json"
      THEN all I get are the “original” compliments.
      1. IF I replace (ouch!) the original compliments.js (your response could be read to imply that) with your compliments.json and use
      THEN I get no compliments at all (but at least no warnings either: that’s impressive).
      Right now, if I want to add my own compliments, all I can do use approach (1), but place your compliments.json into my own git, edit and point to that. Which seems awkward…
      Any help would be appreciated.
        sdetweil @amanzimdwini
        @amanzimdwini the FILE, remote or local must be
                   "name":[" list of strings for name" ],
                    "name2": [ ]
        test that it is a valid JSON file using one of the online validators
        and name can be one of morning, afternoon, evening and anytime.
        and a cron time value
          amanzimdwini @sdetweil
          HERE is my config:
                  module: "compliments",
                  position: "lower_third",
                          remoteFile: "https://gist.githubusercontent.com/ryck/e28a69665b8839f6e9a7acd6b4acc97d/raw/be1dee8f805a433f6ee0fa3556d1927da14e7799/compliments.json",
          //              remoteFile: "compliments.json",
          //              remoteFile: "~/MagicMirror/modules/default/compliments/compliments.json",
          All I do is un-comment the remoteFile lines one at a time to test -
          and the lower two remoteFiles (that are commented out) DO NOT WORK even though the compliments.json file is the one I copied from Git…
          I only want one (local) file; I’m not sure what I am doing wrong.
          Thanks,
          Karl
            @amanzimdwini when I do
            the second one, “compliments.json”
            (without a file)
            I see error in console
             http://0.0.0.0:8090/modules/default/compliments/compliments.json 404 (Not Found)
            if the file is empty I see
            VM143:1 Uncaught SyntaxError: Unexpected end of JSON input
                at JSON.parse (<anonymous>)
                at compliments.js:44
                at XMLHttpRequest.xobj.onreadystatechange (compliments.js:131)
            if I have a syntax error in the file contents I see
            VM298:3 Uncaught SyntaxError: Unexpected string in JSON at position 42
            if the file contains this content (changed from default text to insure it works)
            			"anytime": ["Hey there sexy!"],
            			"morning": ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
            			"afternoon": ["Hello, you beauty!", "You look sexy!", "Looking good today!"],
            			"evening": ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
            			"....-01-01": ["Happy new year!"]
            I see displayed
                           Hello, you beauty!
              YUP - YOUR file works.
              And NOW the copied on from Git to my local directory works too…
              Oh well, I guess my MM just needed to know some master was watching it!
              Thanks for all the help,
              Karl
                APKMILY
                This post is deleted!
