    Touch inverted, can't get it right!! HELP
    2 Posts 2 Posters 1.1k Views 2 Watching
    • M
      M1K3rSz
      Anyone know if its possible to get the touchscreen (42") to run in portrait mode “with” built-in touch (USB) functionality? The display and touch work great in landscape mode, but I cannot get it to work in portrait.
      Adding the following in the config.txt seem to have no effect on touch:
      display_rotate=3
      or
      lcd_rotate=3
      However, lcd_rotate=3 does rotate screen but no luck on touch interface
      I’m running the latest MM2 v2.3.1 config, on a Raspberry Pi 3.
      Please help!!
      • yawnsY
        yawns Moderator
        Please stop posting the same question multiple times. This is closed, please continue here: https://forum.magicmirror.builders/post/37832
