    currentweather isn't working
    modulecurrentweatherweather
    7 Posts 7 Posters 4.4k Views 7 Watching
    • D
      dustin
      I’m new with this whole MagicMirror thing… So please be patient with me.
      Since I had installed the program, the currentweather module is not working (not displayed when running).
      I also edited the code, but I don’t think that’s the issue. If there is a mistake please correct me.
      What could be the problem?
      Best reguards,
      Dustin
      module: “currentweather”,
      position: “top_right”,
      		locationID: "2945024", //Braunschweig +++Location ID from http://openweathermap.org/help/city_list.txt
      		appid: "abcde12345abcde12345abcde12345ab", //openweathermap.org API key.
      		degreeLabel: "true",
      		updateInterval: "300000",
      		animationSpeed: "500",
      		showWindDirection: "true",
      		useKMPHWind: "true",
      		lang: "de"
      • dimitrigoD
        dimitrigo
        @dustin said in currentweather isn’t working:
        currentweather
        Hello, yes me too.
        I’m too a new user !! ;)
          sefeing
          Seems this is due to : https://forum.magicmirror.builders/topic/6878/changing-units-from-metric-to-imperial-breaks-currentweather-module
          I’m having the same issue.
          • O
            oddswop
            I’m going to assume you have an actual API key and that the one you posted here is just a dummy one… if not… then you need to get an API key from openweathermap.org
            • T
              theMadMaker
              I’m having a similar problem:
              It worked fine on first boot but after I changed “units” in config.js, weatherForecast still works fine but currentWeather doesn’t display.
              • T
                Thelonius
                Me too. Current Weather mod just disappeared after updating mm to latest version.
                • R
                  Riotz
                  It would seem that the CurrentWeather module does not like it when you change to imperial units.
