    Changing units from 'metric' to 'imperial' breaks currentweather module
    14 Posts 9 Posters 12.8k Views 9 Watching
    • Z Offline
      zorrotech
      Changing my config.js units from ‘metric’ to ‘imperial’ causes my currentweather module not to appear. Any thoughts?
      • V Offline
        vaju0503 @zorrotech
        @zorrotech seems I’m having the same issue, I just posted about it not working, but I now see that I too am having this same issue. The weatherforcast module still seems to work in imperial but the current weather did break.
          dplawrance
          So glad to know that someone else is experiencing the same thing (well, not actually glad that someone else is having a problem…) All was well until performing the v2.3.1 update, yesterday. The weatherforecast module is fine, but the current weather module is not displaying, and I do have the imperial unit option set.
            dplawrance
            Confirmed that switching to metric restores a display.
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @dplawrance
              @dplawrance its fixed on the develop branch
              https://github.com/MichMich/MagicMirror/commit/10eb41d31943a4495bf4c4674d52d0b9631a7446
              • V Offline
                vaju0503
                Agreed it does appear to fix what was broken. :)
                • C Offline
                  Cyberwrights
                  Wow I was really starting to lose my mind over this one. Have been going over and over my config.js file.
                  MMM-GoogleAssistant
                  MMM-Hue
                  MMM-MyCommute
                  MMM-Formula1
                  MMM-SystemStats
                  MMM-moon-phases
                    sefeing
                    @strawberry-3.141 said in Changing units from ‘metric’ to ‘imperial’ breaks currentweather module:
                    Having this issue as well, with the same reproduction, changing to metric brings it back but imperial breaks it.
                    How do I pull the file from the develop branch, as someone fairly new to all this?
                    • N Offline
                      ninjabreadman @sefeing
                      @sefeing Use the instructions here. You want to git checkout the branch by name (in this case, run git checkout develop in the ~/MagicMirror folder).
                      You might even be able to use git cherry-pick 10eb41d31943a4495bf4c4674d52d0b9631a7446 instead, to stay on master but incorporate that specific fix. YMMV.
                      Problem with config or JavaScript? Copy/paste it into JSHint.
                      Check out the detailed walkthroughs on install, config, modules, etc.
                        sefeing @ninjabreadman
                        @ninjabreadman maybe a silly question, but can I… download and manually replace the file? git cherry-pick failed with the reason:
                        error: cherry-pick is not possible because you have unmerged files.
                        hint: Fix them up in the work tree, and then use 'git add/rm ’
                        hint: as appropriate to mark resolution and make a commit, or use
                        hint: ‘git commit -a’.
                        fatal: cherry-pick failed
                        edit… scratch that, it just started working again…
                        • V Offline
                          vaju0503
                          Just look at the history of the change that was made in the other branch… it’s in modules/default/currentweather the script you need to update is currentweather.js
                          I just used an SFTP connection to get into my pi, went to the directory and uploaded the new script. You have to change the following in the script lines 410 and 411. Take note in the case sensitive variable of windChillInF it was changed from windchillinF. You could do it from terminal too using nano or whatever your favorite editor is. That’s what I ended up doing until this gets merged up into the main pull.
                          var windChillInF = Math.round(35.74+0.6215*tempInF35.75*Math.pow(windInMph,0.16)+0.4275*tempInF*Math.pow(windInMph,0.16));
                          var windChillInC = (windChillInF - 32) * (5/9);
                          Obviously after you fix it you’ll have to restart MM or just do a reboot and it should fix itself.
                            dplawrance
                            Thank you!
                            That was so simple, and it works! I tried (and failed) to switch over to the the develop branch, learned a lot more about git than I knew, but not enough.
                              ryanvox
                              My current weather is still broke after update. Tried git checkout and it says my branch is up to date with origin/master. When I change back to metric from Imperial it kind of works. It only gives me temp and tells me its snowing or raining or whatever. Its missing sunset time, wind speed, etc. Also changed the script as stated above in modules/default/currentweather. rebooted and still no luck.
                              EDIT
                              Was able to get the Imperial system working but still missing wind speed, sunset/sunrise time
                              • dorfman2D Offline
                                dorfman2
                                Some days my current Weather module works, some days it doesn’t. My mirror is set to restart daily at 1am. It’s been working the past 2 days, but hadn’t worked the prior week. I haven’t had time to look into it, all I did was update it to 2.3.1 on a raspberry pi 3 B+.
