    Changing units from 'metric' to 'imperial' breaks currentweather module
    14 Posts 9 Posters 11.8k Views 9 Watching
      dplawrance
      So glad to know that someone else is experiencing the same thing (well, not actually glad that someone else is having a problem…) All was well until performing the v2.3.1 update, yesterday. The weatherforecast module is fine, but the current weather module is not displaying, and I do have the imperial unit option set.
        dplawrance
        Confirmed that switching to metric restores a display.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @dplawrance
          @dplawrance its fixed on the develop branch
          https://github.com/MichMich/MagicMirror/commit/10eb41d31943a4495bf4c4674d52d0b9631a7446
          • V Offline
            vaju0503
            Agreed it does appear to fix what was broken. :)
              Cyberwrights
              Wow I was really starting to lose my mind over this one. Have been going over and over my config.js file.
              MMM-GoogleAssistant
              MMM-Hue
              MMM-MyCommute
              MMM-Formula1
              MMM-SystemStats
              MMM-moon-phases
                sefeing
                @strawberry-3.141 said in Changing units from ‘metric’ to ‘imperial’ breaks currentweather module:
                Having this issue as well, with the same reproduction, changing to metric brings it back but imperial breaks it.
                How do I pull the file from the develop branch, as someone fairly new to all this?
                • N Offline
                  ninjabreadman @sefeing
                  @sefeing Use the instructions here. You want to git checkout the branch by name (in this case, run git checkout develop in the ~/MagicMirror folder).
                  You might even be able to use git cherry-pick 10eb41d31943a4495bf4c4674d52d0b9631a7446 instead, to stay on master but incorporate that specific fix. YMMV.
                    sefeing @ninjabreadman
                    @ninjabreadman maybe a silly question, but can I… download and manually replace the file? git cherry-pick failed with the reason:
                    error: cherry-pick is not possible because you have unmerged files.
                    hint: Fix them up in the work tree, and then use 'git add/rm ’
                    hint: as appropriate to mark resolution and make a commit, or use
                    hint: ‘git commit -a’.
                    fatal: cherry-pick failed
                    edit… scratch that, it just started working again…
                    • V Offline
                      vaju0503
                      Just look at the history of the change that was made in the other branch… it’s in modules/default/currentweather the script you need to update is currentweather.js
                      I just used an SFTP connection to get into my pi, went to the directory and uploaded the new script. You have to change the following in the script lines 410 and 411. Take note in the case sensitive variable of windChillInF it was changed from windchillinF. You could do it from terminal too using nano or whatever your favorite editor is. That’s what I ended up doing until this gets merged up into the main pull.
                      var windChillInF = Math.round(35.74+0.6215*tempInF35.75*Math.pow(windInMph,0.16)+0.4275*tempInF*Math.pow(windInMph,0.16));
                      var windChillInC = (windChillInF - 32) * (5/9);
                      Obviously after you fix it you’ll have to restart MM or just do a reboot and it should fix itself.
                        dplawrance
                        Thank you!
                        That was so simple, and it works! I tried (and failed) to switch over to the the develop branch, learned a lot more about git than I knew, but not enough.
