    MMM-CalendarExt
    198 Posts 45 Posters 272.2k Views 45 Watching
      A Former User @MortenVS
      @MortenVS
      1. You cannot use “2 upcoming views” at the same time. sorry. If you use “profile”, you can select or change to show the view from “multi upcoming views”, but not together.
      2. I hadn’t imagined that kind of function. I think some kind of filtering function would be needed for your purpose. When I have a time, I might add that.
      • MortenVSM
        MortenVS
        Thanks for your update and for considering the feature.
        Hope to see filtering sometime in the future in this already great module.
          d3r
          @Sean
          Hey, is there a way to rename/hide the location of an event for a specific calendar?
          Similar to the replaceTitle configuration.
          Thanks,
          ? 1 Reply Last reply
            A Former User @d3r
            @d3r
            You can hide location by modifying CSS, but no way to rename. You should do it in your feed.
              simzdk
              I have a problem that a all day event, also shows up the next day. Have tried both daily and weeks view, and same error.
              I use locale da-DK
              N ? 2 Replies Last reply
              • N
                ninjabreadman @simzdk
                @simzdk Seems @nn1mda is having the same problem here. @Sean is busy, but maybe we can convince him to have a look. As @modderhut suggests, best to open an issue on Github.
                  A Former User @simzdk
                  @simzdk
                  Send me your configuration and ical to test.
                  My email is in my profile.
                  And as @ninjabreadman said, I’m so busy to catch up the forum. if you leave your request in Github, I’ll try to support.
                    simzdk @Guest
                    @Sean, Thanks!
                    Email sent!
                    • A
                      abetterway
                      This may be a silly question, but I am pretty new to using git. I am wanting to install this module on a RPI Zero and cannot figure out how to “git clone” the sub tree repository with the RPI 1 compatibility changes.
                      Is there a way to tell the git to clone from a sub folder/branch?
                      Thanks!
                      N 1 Reply Last reply
                      • N
                        ninjabreadman @abetterway
                        @abetterway I think you mean switch the origin branch of the MMM-CalendarExt repository to forRPI1.
                        In this case, use git checkout forRPI1 within the ~/MagicMirror/modules/MMM-CalendarExt directory.
                        • A
                          abetterway
                          That’s exactly what I needed. Thank you!
                            ragincajunintx
                              jckubiaczyk
                              I would like to know if it is possible to have a visual per hour.
                              For example from 8h to 18h.
                              Thank you
                                Bernhard
                                Hi Guys!
                                I hope you can help me. ;-)
                                I’m looking for a way to hide the column “KW”.
                                So the first column should be the “Monday (Mo)” column - at the " weeks" view.
                                (Hide the red marked column)
                                Is that possible?!
                                • Y
                                  yawns Moderator
                                  Yes, look at https://github.com/eouia/MMM-CalendarExt/wiki/Configuration, search for showWeeks and add that to your config.
                                  B 1 Reply Last reply
                                    Bernhard @yawns
                                    @yawns
                                    THANK YOU
                                    It’s so easy - I have to be blind
                                      ragincajunintx
                                      Hi… thank you so much for building this module… I am trying to customize the views… i originally setup weeks view with just one week… got my css where I wanted it, but I realized what i really wanted was a days view… the days view is much different and doesn’t show times on the events… can you help me get exactly like my picture, but in the days view? with the week starting on monday. I have my locale set to en-US…
                                      Thursday, Friday, and Saturday day names are missing though…
                                      • G
                                        ganther
                                        First of all thankyou for this great module!!
                                        One little question. I use my calendar in weekly View with 2 weeks shown.
                                        I would like to reduce the black margin left and right. Could you tell me which code I have to add in the custom.css to define the width of the calendar?
                                        Thank you so much
                                        Sandy
                                        • F
                                          flashnatic
                                          Hi :),
                                          Is it possible to start MMM-CalendarExt hidden and let it show up with this.sendNotification(‘CHANGED_PROFILE’, {to:‘daddy’}) or something like that?`
                                          Background ist that I want to use Buttons at my Mirror to hide all other modules and show CalendarExt in fullscreen (MMM-Toggle).
                                          Problem is that Calendar do not refresh in hidden mode.
                                          my config:
                                          			module: 'MMM-CalendarExt',
                                          			position: "top_left", //anywhere. It is not related to real position of view
                                          			  system: {
                                          				show: ["weeks"], //you can select views which you want to show.
                                          				locale: 'de',
                                          				showEmptyView: 1,
                                          				views: {
                                          					weeks: {
                                          						position: "middle_center",
                                          						showWeeks: 1,
                                          						weeksTitle: 'Woche',
                                          						weeksFormat: 'WW',
                                          						weekdayFormat: 'dd',
                                          						titleFormat : 'D',
                                          						overTitleFormat : 'D. MMM',
                                          						monthTitleFormat: "MMMM",
                                          						counts: 6,
                                          						overflowRolling: 1,
                                          						oneLineEvent: 1,
                                          					  styleName:"style5",
                                          					  url: "https://calendar.google.com...
                                          					  styleName:"style15",
                                          					  symbol:"birthday@em",
                                          					  styleName:"style3",
                                          					  symbol:"wastebasket@em",
                                          					  name: "WM Kalender",
                                          					  symbol:"soccer@em",
                                          					  url: "https://calendar.google.com....
                                          Thanks in advance :)
                                            redink
                                            I am having problems with my mirror, and I can’t figure out which module is the culprit. In my logs, I am seeing something related to this one, so maybe someone could help me out. Any ideas what the error below means?
                                            0|mm       | Whoops! There was an uncaught exception...
                                            0|mm       | TypeError: Cannot read property 'replace' of null
                                            0|mm       |     at new Calendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendar.js:38:32)
                                            0|mm       |     at Calendars.registerCalendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendars.js:37:18)
                                            0|mm       |     at Class.cmd_ADD_CALENDAR (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:45:20)
                                            0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:36:14)
                                            0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                                            0|mm       |     at emitTwo (events.js:125:13)
                                            0|mm       |     at Socket.emit (events.js:213:7)
                                            0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                                            0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                                            0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                                            0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            • 10
                                            • 4 / 10
