    MMM-CalendarExt
    198 Posts 45 Posters 262.6k Views 45 Watching
    • MortenVSM Offline
      MortenVS
      Thanks a lot for a great module!!!
      Currently doing my finishing touches on my MagicMirror and CalendarExt.
      I’m using 1 daily view (bottom_bar) and 2 column view (top_left), each with a dedicated google calendar.
      Have tried to configure 2 upcoming view, still without any luck.
      I have 2 questions:
      1. How can I set up CalendarExt to use 2 upcoming views or reconfigure one of the other views to function and present as the upcoming view?
        (Preferable without being affected by future updates.)
      2. Is there any method (or planned feature) to limit my calendars from 3 to 1 by filtering, including or excluding events per view?
        Example:
                              title: "Birthdays",
                              views: ['upcoming'],
      			includeEvent: ["/Birthday/gi']
                              url: "https://calendar.google.com/calendar/ical/....",
                              views: ['daily'],
      			excludeEvent: ["/Birthday/gi']
      Hope you can help.
        [[global:former-user]] @MortenVS
        @MortenVS
        1. You cannot use “2 upcoming views” at the same time. sorry. If you use “profile”, you can select or change to show the view from “multi upcoming views”, but not together.
        2. I hadn’t imagined that kind of function. I think some kind of filtering function would be needed for your purpose. When I have a time, I might add that.
        • MortenVSM Offline
          MortenVS
          Thanks for your update and for considering the feature.
          Hope to see filtering sometime in the future in this already great module.
            d3r
            @Sean
            Hey, is there a way to rename/hide the location of an event for a specific calendar?
            Similar to the replaceTitle configuration.
            Thanks,
              [[global:former-user]] @d3r
              @d3r
              You can hide location by modifying CSS, but no way to rename. You should do it in your feed.
                simzdk
                I have a problem that a all day event, also shows up the next day. Have tried both daily and weeks view, and same error.
                I use locale da-DK
                N ? 2 Replies Last reply Reply Quote 0
                • N Offline
                  ninjabreadman @simzdk
                  @simzdk Seems @nn1mda is having the same problem here. @Sean is busy, but maybe we can convince him to have a look. As @modderhut suggests, best to open an issue on Github.
                    [[global:former-user]] @simzdk
                    @simzdk
                    Send me your configuration and ical to test.
                    My email is in my profile.
                    And as @ninjabreadman said, I’m so busy to catch up the forum. if you leave your request in Github, I’ll try to support.
                      simzdk @Guest
                      @Sean, Thanks!
                      Email sent!
                        abetterway
                        This may be a silly question, but I am pretty new to using git. I am wanting to install this module on a RPI Zero and cannot figure out how to “git clone” the sub tree repository with the RPI 1 compatibility changes.
                        Is there a way to tell the git to clone from a sub folder/branch?
                        Thanks!
                        • N Offline
                          ninjabreadman @abetterway
                          @abetterway I think you mean switch the origin branch of the MMM-CalendarExt repository to forRPI1.
                          In this case, use git checkout forRPI1 within the ~/MagicMirror/modules/MMM-CalendarExt directory.
                            abetterway
                            That’s exactly what I needed. Thank you!
                              ragincajunintx
                                jckubiaczyk
                                I would like to know if it is possible to have a visual per hour.
                                For example from 8h to 18h.
                                Thank you
                                  Bernhard
                                  Hi Guys!
                                  I hope you can help me. ;-)
                                  I’m looking for a way to hide the column “KW”.
                                  So the first column should be the “Monday (Mo)” column - at the " weeks" view.
                                  (Hide the red marked column)
                                  Is that possible?!
                                  • Y Offline
                                    yawns Moderator
                                    Yes, look at https://github.com/eouia/MMM-CalendarExt/wiki/Configuration, search for showWeeks and add that to your config.
                                      Bernhard @yawns
                                      @yawns
                                      THANK YOU
                                      It’s so easy - I have to be blind
                                        ragincajunintx
                                        Hi… thank you so much for building this module… I am trying to customize the views… i originally setup weeks view with just one week… got my css where I wanted it, but I realized what i really wanted was a days view… the days view is much different and doesn’t show times on the events… can you help me get exactly like my picture, but in the days view? with the week starting on monday. I have my locale set to en-US…
                                        Thursday, Friday, and Saturday day names are missing though…
                                        • G Offline
                                          ganther
                                          First of all thankyou for this great module!!
                                          One little question. I use my calendar in weekly View with 2 weeks shown.
                                          I would like to reduce the black margin left and right. Could you tell me which code I have to add in the custom.css to define the width of the calendar?
                                          Thank you so much
                                          Sandy
                                          • F Offline
                                            flashnatic
                                            Hi :),
                                            Is it possible to start MMM-CalendarExt hidden and let it show up with this.sendNotification(‘CHANGED_PROFILE’, {to:‘daddy’}) or something like that?`
                                            Background ist that I want to use Buttons at my Mirror to hide all other modules and show CalendarExt in fullscreen (MMM-Toggle).
                                            Problem is that Calendar do not refresh in hidden mode.
                                            my config:
                                            			module: 'MMM-CalendarExt',
                                            			position: "top_left", //anywhere. It is not related to real position of view
                                            			  system: {
                                            				show: ["weeks"], //you can select views which you want to show.
                                            				locale: 'de',
                                            				showEmptyView: 1,
                                            				views: {
                                            					weeks: {
                                            						position: "middle_center",
                                            						showWeeks: 1,
                                            						weeksTitle: 'Woche',
                                            						weeksFormat: 'WW',
                                            						weekdayFormat: 'dd',
                                            						titleFormat : 'D',
                                            						overTitleFormat : 'D. MMM',
                                            						monthTitleFormat: "MMMM",
                                            						counts: 6,
                                            						overflowRolling: 1,
                                            						oneLineEvent: 1,
                                            					  styleName:"style5",
                                            					  url: "https://calendar.google.com...
                                            					  styleName:"style15",
                                            					  symbol:"birthday@em",
                                            					  styleName:"style3",
                                            					  symbol:"wastebasket@em",
                                            					  name: "WM Kalender",
                                            					  symbol:"soccer@em",
                                            					  url: "https://calendar.google.com....
                                            Thanks in advance :)
                                            • 10
                                            • 4 / 10
