    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
      jckubiaczyk
      I would like to know if it is possible to have a visual per hour.
      For example from 8h to 18h.
      Thank you
        Bernhard
        Hi Guys!
        I hope you can help me. ;-)
        I’m looking for a way to hide the column “KW”.
        So the first column should be the “Monday (Mo)” column - at the " weeks" view.
        (Hide the red marked column)
        Is that possible?!
        • yawnsY
          yawns Moderator
          Yes, look at https://github.com/eouia/MMM-CalendarExt/wiki/Configuration, search for showWeeks and add that to your config.
          B 1 Reply Last reply
            Bernhard @yawns
            @yawns
            THANK YOU
            It’s so easy - I have to be blind
              ragincajunintx
              Hi… thank you so much for building this module… I am trying to customize the views… i originally setup weeks view with just one week… got my css where I wanted it, but I realized what i really wanted was a days view… the days view is much different and doesn’t show times on the events… can you help me get exactly like my picture, but in the days view? with the week starting on monday. I have my locale set to en-US…
              Thursday, Friday, and Saturday day names are missing though…
              • G
                ganther
                First of all thankyou for this great module!!
                One little question. I use my calendar in weekly View with 2 weeks shown.
                I would like to reduce the black margin left and right. Could you tell me which code I have to add in the custom.css to define the width of the calendar?
                Thank you so much
                Sandy
                • F
                  flashnatic
                  Hi :),
                  Is it possible to start MMM-CalendarExt hidden and let it show up with this.sendNotification(‘CHANGED_PROFILE’, {to:‘daddy’}) or something like that?`
                  Background ist that I want to use Buttons at my Mirror to hide all other modules and show CalendarExt in fullscreen (MMM-Toggle).
                  Problem is that Calendar do not refresh in hidden mode.
                  my config:
                  			module: 'MMM-CalendarExt',
                  			position: "top_left", //anywhere. It is not related to real position of view
                  			  system: {
                  				show: ["weeks"], //you can select views which you want to show.
                  				locale: 'de',
                  				showEmptyView: 1,
                  				views: {
                  					weeks: {
                  						position: "middle_center",
                  						showWeeks: 1,
                  						weeksTitle: 'Woche',
                  						weeksFormat: 'WW',
                  						weekdayFormat: 'dd',
                  						titleFormat : 'D',
                  						overTitleFormat : 'D. MMM',
                  						monthTitleFormat: "MMMM",
                  						counts: 6,
                  						overflowRolling: 1,
                  						oneLineEvent: 1,
                  					  styleName:"style5",
                  					  url: "https://calendar.google.com...
                  					  styleName:"style15",
                  					  symbol:"birthday@em",
                  					  styleName:"style3",
                  					  symbol:"wastebasket@em",
                  					  name: "WM Kalender",
                  					  symbol:"soccer@em",
                  					  url: "https://calendar.google.com....
                  Thanks in advance :)
                    redink
                    I am having problems with my mirror, and I can’t figure out which module is the culprit. In my logs, I am seeing something related to this one, so maybe someone could help me out. Any ideas what the error below means?
                    0|mm       | Whoops! There was an uncaught exception...
                    0|mm       | TypeError: Cannot read property 'replace' of null
                    0|mm       |     at new Calendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendar.js:38:32)
                    0|mm       |     at Calendars.registerCalendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendars.js:37:18)
                    0|mm       |     at Class.cmd_ADD_CALENDAR (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:45:20)
                    0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:36:14)
                    0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                    0|mm       |     at emitTwo (events.js:125:13)
                    0|mm       |     at Socket.emit (events.js:213:7)
                    0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                    0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                    0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                    0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    • V
                      Vauxdvihl
                      @Sean
                      I have done an update from your module.
                      But know the view of my “bank holidays” does not work anymore (the google calender dates are still working fine)
                      Can it be that there is some problem accordingly.
                      I am using via “webcal” these datas from the following adress:
                      www.ecoline-media.de/ics/bayern_gf.ics
                      Thanks for you help and your great work
                      Cheers
                      ? 1 Reply Last reply
                        A Former User @Vauxdvihl
                        @vauxdvihl
                        In my system, it works.
                        Log:
                        [CALEXT] http://www.ecoline-media.de/ics/bayern_gf.ics  >> Fetch starts.
                        { state: 'renewed',
                          lastFetchedTime: '18-09-03 08:52:25',
                          lastFetchedEvents: 8,
                          lastFetchedOldEvents: 0,
                          lastServedEvents: 8,
                          error: null }
                        Config:
                              //disabled:true,
                                system: {
                                  show: ['monthly']
                                views: {
                                  monthly: {
                                    counts:6
                                    url: "http://www.ecoline-media.de/ics/bayern_gf.ics"
                        Is there any symptom (eg. error logs) for your issue?
                        • V
                          Vauxdvihl
                          @Sean
                          It is strange
                          I have copied the file to the system
                          Log:
                          [CALEXT] http://localhost:8080/modules/bayern_gf.ics  >>
                          0|mm       | { state: 'renewed',
                          0|mm       |   lastFetchedTime: '18-09-08 09:07:31',
                          0|mm       |   lastFetchedEvents: 17,
                          0|mm       |   lastFetchedOldEvents: 0,
                          0|mm       |   lastServedEvents: 17,
                          0|mm       |   error: null }
                          Config:
                          					url: "http://localhost:8080/modules/bayern_gf.ics",
                          					styleName: "style1",
                          					symbol: 'de@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					interval: 24*60*60*1000,
                          But the module will not show the datas in the calendar.
                          Other google calendars are shown
                          Any idea?
                          Thank
                            @vauxdvihl
                            Show me the full config of this module.
                            • V
                              Vauxdvihl
                              @Sean
                              Here u r
                              				position: "lower_third", //anywhere. It is not related to real position of view
                              				config: { // Read below
                              				system: {
                              				  show: [/*'current','upcoming',*/'weeks'],
                              				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                              				  showEmptyView: 0,
                              				  fullDayEventLocalize: 1,
                              				  redrawInterval: 30*60*1000, //minimum 60000
                              				  useProfileConfig: 0,
                              				  startProfile: ''
                              				 views: {
                              						current: {
                              						  position: "top_center",
                              						  title: "Heute",
                              						  limit: 2,
                              						upcoming: {
                              						  title: "Demnächst",
                              						  limit: 2,
                              						weeks: {
                              						  position: "bottom_bar",
                              						  title: "Überblick",
                              						  counts: 2,
                              					symbol: 'de@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					url: "http://localhost:8080/modules/abfallkalender.ics",
                              					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
                              					symbol: 'put_litter_in_its_place@em',
                              					maxEntries: 50,
                              					maxDays:365,
                              					url: "https://calendar.google.com/calendar______",
                              					styleName: "style19",
                              					symbol: 'guitar@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					name: "Familie Warneke",
                              					styleName: "style6",
                              					symbol: 'man-woman-boy-boy@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					url: "https://calendar.google.com/calendar_____",
                              					styleName: "style11",
                              					symbol: 'bike@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					styleName: "style12",
                              					symbol: 'birthday@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					symbol: 'crown@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              					url: "https://calendar.google.com/calendar____",
                              					symbol: 'baby@em',
                              				    maxEntries: 50,
                              					maxDays:365,
                              ? J 2 Replies Last reply
                                @vauxdvihl
                                Hmmm, in my memory of last test, there is no event of Byern holiday in September. Your config would show events in 2 weeks. I think it seems to be normal. Isn’t it?
                                • V
                                  Vauxdvihl
                                  @Sean
                                  Sorry no
                                  Currently school is out (summer)
                                  Starts again on tuesday next week
                                  So there should be an entry called “Sommerferien” in the calendar for this week and for next monday.
                                  But i will set it like your request
                                    @vauxdvihl I’ve found what was wrong and fixed it. sorry. update and try again.
                                    V 1 Reply Last reply
                                      SK4018
                                      Hi all,
                                      stupid question for you guys. How do I update the module? My mirror says I’m behinde two updates. Thanks!
                                        A Former User @SK4018
                                        @sk4018
                                        cd ~/MagicMirror/modules/MMM-CalendarExt
                                        git pull
                                        • T
                                          Tabbe
                                          Hi all!
                                          Is there way to format the date of current and upcoming views? I used
                                                    titleFormat: "dddd",
                                                    overTitleFormat : "dddd",
                                          But still date format is unchanged.
                                            A Former User @Tabbe
                                            @tabbe
                                            https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#defaultview
                                            Use dateFormat
                                            T 1 Reply Last reply
                                            • 10
                                            • 4 / 10
