    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • Y
      yawns Moderator
      Yes, look at https://github.com/eouia/MMM-CalendarExt/wiki/Configuration, search for showWeeks and add that to your config.
        Bernhard @yawns
        @yawns
        THANK YOU
        It’s so easy - I have to be blind
          ragincajunintx
          Hi… thank you so much for building this module… I am trying to customize the views… i originally setup weeks view with just one week… got my css where I wanted it, but I realized what i really wanted was a days view… the days view is much different and doesn’t show times on the events… can you help me get exactly like my picture, but in the days view? with the week starting on monday. I have my locale set to en-US…
          Thursday, Friday, and Saturday day names are missing though…
          • G
            ganther
            First of all thankyou for this great module!!
            One little question. I use my calendar in weekly View with 2 weeks shown.
            I would like to reduce the black margin left and right. Could you tell me which code I have to add in the custom.css to define the width of the calendar?
            Thank you so much
            Sandy
            • F
              flashnatic
              Hi :),
              Is it possible to start MMM-CalendarExt hidden and let it show up with this.sendNotification(‘CHANGED_PROFILE’, {to:‘daddy’}) or something like that?`
              Background ist that I want to use Buttons at my Mirror to hide all other modules and show CalendarExt in fullscreen (MMM-Toggle).
              Problem is that Calendar do not refresh in hidden mode.
              my config:
              			module: 'MMM-CalendarExt',
              			position: "top_left", //anywhere. It is not related to real position of view
              			  system: {
              				show: ["weeks"], //you can select views which you want to show.
              				locale: 'de',
              				showEmptyView: 1,
              				views: {
              					weeks: {
              						position: "middle_center",
              						showWeeks: 1,
              						weeksTitle: 'Woche',
              						weeksFormat: 'WW',
              						weekdayFormat: 'dd',
              						titleFormat : 'D',
              						overTitleFormat : 'D. MMM',
              						monthTitleFormat: "MMMM",
              						counts: 6,
              						overflowRolling: 1,
              						oneLineEvent: 1,
              					  styleName:"style5",
              					  url: "https://calendar.google.com...
              					  styleName:"style15",
              					  symbol:"birthday@em",
              					  styleName:"style3",
              					  symbol:"wastebasket@em",
              					  name: "WM Kalender",
              					  symbol:"soccer@em",
              					  url: "https://calendar.google.com....
              Thanks in advance :)
                redink
                I am having problems with my mirror, and I can’t figure out which module is the culprit. In my logs, I am seeing something related to this one, so maybe someone could help me out. Any ideas what the error below means?
                0|mm       | Whoops! There was an uncaught exception...
                0|mm       | TypeError: Cannot read property 'replace' of null
                0|mm       |     at new Calendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendar.js:38:32)
                0|mm       |     at Calendars.registerCalendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendars.js:37:18)
                0|mm       |     at Class.cmd_ADD_CALENDAR (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:45:20)
                0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:36:14)
                0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                0|mm       |     at emitTwo (events.js:125:13)
                0|mm       |     at Socket.emit (events.js:213:7)
                0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                • V
                  Vauxdvihl
                  @Sean
                  I have done an update from your module.
                  But know the view of my “bank holidays” does not work anymore (the google calender dates are still working fine)
                  Can it be that there is some problem accordingly.
                  I am using via “webcal” these datas from the following adress:
                  www.ecoline-media.de/ics/bayern_gf.ics
                  Thanks for you help and your great work
                  Cheers
                    A Former User @Vauxdvihl
                    @vauxdvihl
                    In my system, it works.
                    Log:
                    [CALEXT] http://www.ecoline-media.de/ics/bayern_gf.ics  >> Fetch starts.
                    { state: 'renewed',
                      lastFetchedTime: '18-09-03 08:52:25',
                      lastFetchedEvents: 8,
                      lastFetchedOldEvents: 0,
                      lastServedEvents: 8,
                      error: null }
                    Config:
                          //disabled:true,
                            system: {
                              show: ['monthly']
                            views: {
                              monthly: {
                                counts:6
                                url: "http://www.ecoline-media.de/ics/bayern_gf.ics"
                    Is there any symptom (eg. error logs) for your issue?
                    • V
                      Vauxdvihl
                      @Sean
                      It is strange
                      I have copied the file to the system
                      Log:
                      [CALEXT] http://localhost:8080/modules/bayern_gf.ics  >>
                      0|mm       | { state: 'renewed',
                      0|mm       |   lastFetchedTime: '18-09-08 09:07:31',
                      0|mm       |   lastFetchedEvents: 17,
                      0|mm       |   lastFetchedOldEvents: 0,
                      0|mm       |   lastServedEvents: 17,
                      0|mm       |   error: null }
                      Config:
                      					url: "http://localhost:8080/modules/bayern_gf.ics",
                      					styleName: "style1",
                      					symbol: 'de@em',
                      				    maxEntries: 50,
                      					maxDays:365,
                      					interval: 24*60*60*1000,
                      But the module will not show the datas in the calendar.
                      Other google calendars are shown
                      Any idea?
                      Thank
                        @vauxdvihl
                        Show me the full config of this module.
                        • V
                          Vauxdvihl
                          @Sean
                          Here u r
                          				position: "lower_third", //anywhere. It is not related to real position of view
                          				config: { // Read below
                          				system: {
                          				  show: [/*'current','upcoming',*/'weeks'],
                          				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                          				  showEmptyView: 0,
                          				  fullDayEventLocalize: 1,
                          				  redrawInterval: 30*60*1000, //minimum 60000
                          				  useProfileConfig: 0,
                          				  startProfile: ''
                          				 views: {
                          						current: {
                          						  position: "top_center",
                          						  title: "Heute",
                          						  limit: 2,
                          						upcoming: {
                          						  title: "Demnächst",
                          						  limit: 2,
                          						weeks: {
                          						  position: "bottom_bar",
                          						  title: "Überblick",
                          						  counts: 2,
                          					symbol: 'de@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					url: "http://localhost:8080/modules/abfallkalender.ics",
                          					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
                          					symbol: 'put_litter_in_its_place@em',
                          					maxEntries: 50,
                          					maxDays:365,
                          					url: "https://calendar.google.com/calendar______",
                          					styleName: "style19",
                          					symbol: 'guitar@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					name: "Familie Warneke",
                          					styleName: "style6",
                          					symbol: 'man-woman-boy-boy@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					url: "https://calendar.google.com/calendar_____",
                          					styleName: "style11",
                          					symbol: 'bike@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					styleName: "style12",
                          					symbol: 'birthday@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					symbol: 'crown@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          					url: "https://calendar.google.com/calendar____",
                          					symbol: 'baby@em',
                          				    maxEntries: 50,
                          					maxDays:365,
                          ? J 2 Replies Last reply Reply Quote 0
                            @vauxdvihl
                            Hmmm, in my memory of last test, there is no event of Byern holiday in September. Your config would show events in 2 weeks. I think it seems to be normal. Isn’t it?
                            • V
                              Vauxdvihl
                              @Sean
                              Sorry no
                              Currently school is out (summer)
                              Starts again on tuesday next week
                              So there should be an entry called “Sommerferien” in the calendar for this week and for next monday.
                              But i will set it like your request
                                @vauxdvihl I’ve found what was wrong and fixed it. sorry. update and try again.
                                  SK4018
                                  Hi all,
                                  stupid question for you guys. How do I update the module? My mirror says I’m behinde two updates. Thanks!
                                    A Former User @SK4018
                                    @sk4018
                                    cd ~/MagicMirror/modules/MMM-CalendarExt
                                    git pull
                                    • T
                                      Tabbe
                                      Hi all!
                                      Is there way to format the date of current and upcoming views? I used
                                                titleFormat: "dddd",
                                                overTitleFormat : "dddd",
                                      But still date format is unchanged.
                                        A Former User @Tabbe
                                        @tabbe
                                        https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#defaultview
                                        Use dateFormat
                                        • T
                                          Tabbe @Guest
                                          @sean said in MMM-CalendarExt:
                                          @tabbe
                                          Use dateFormat
                                          I did try with that but still it remains unchanged.
                                                  current: {
        title: "Test",
        dateFormat: "dddd",
        position: 'top_left',
        useRelative: 0,
        limit:2
                                          I also tried without other formating and with basic M.D format.
                                          alt text
                                            @tabbe ‘dddd’ means the weekday name of target date/time. What exactly do you want to display as?
                                            • 10
                                            • 5 / 10
