    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • G
      ganther
      First of all thankyou for this great module!!
      One little question. I use my calendar in weekly View with 2 weeks shown.
      I would like to reduce the black margin left and right. Could you tell me which code I have to add in the custom.css to define the width of the calendar?
      Thank you so much
      Sandy
      • F
        flashnatic
        Hi :),
        Is it possible to start MMM-CalendarExt hidden and let it show up with this.sendNotification(‘CHANGED_PROFILE’, {to:‘daddy’}) or something like that?`
        Background ist that I want to use Buttons at my Mirror to hide all other modules and show CalendarExt in fullscreen (MMM-Toggle).
        Problem is that Calendar do not refresh in hidden mode.
        my config:
        			module: 'MMM-CalendarExt',
        			position: "top_left", //anywhere. It is not related to real position of view
        			  system: {
        				show: ["weeks"], //you can select views which you want to show.
        				locale: 'de',
        				showEmptyView: 1,
        				views: {
        					weeks: {
        						position: "middle_center",
        						showWeeks: 1,
        						weeksTitle: 'Woche',
        						weeksFormat: 'WW',
        						weekdayFormat: 'dd',
        						titleFormat : 'D',
        						overTitleFormat : 'D. MMM',
        						monthTitleFormat: "MMMM",
        						counts: 6,
        						overflowRolling: 1,
        						oneLineEvent: 1,
        					  styleName:"style5",
        					  url: "https://calendar.google.com...
        					  styleName:"style15",
        					  symbol:"birthday@em",
        					  styleName:"style3",
        					  symbol:"wastebasket@em",
        					  name: "WM Kalender",
        					  symbol:"soccer@em",
        					  url: "https://calendar.google.com....
        Thanks in advance :)
          redink
          I am having problems with my mirror, and I can’t figure out which module is the culprit. In my logs, I am seeing something related to this one, so maybe someone could help me out. Any ideas what the error below means?
          0|mm       | Whoops! There was an uncaught exception...
          0|mm       | TypeError: Cannot read property 'replace' of null
          0|mm       |     at new Calendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendar.js:38:32)
          0|mm       |     at Calendars.registerCalendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendars.js:37:18)
          0|mm       |     at Class.cmd_ADD_CALENDAR (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:45:20)
          0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:36:14)
          0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
          0|mm       |     at emitTwo (events.js:125:13)
          0|mm       |     at Socket.emit (events.js:213:7)
          0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
          0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
          0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          • V
            Vauxdvihl
            @Sean
            I have done an update from your module.
            But know the view of my “bank holidays” does not work anymore (the google calender dates are still working fine)
            Can it be that there is some problem accordingly.
            I am using via “webcal” these datas from the following adress:
            www.ecoline-media.de/ics/bayern_gf.ics
            Thanks for you help and your great work
            Cheers
              A Former User @Vauxdvihl
              @vauxdvihl
              In my system, it works.
              Log:
              [CALEXT] http://www.ecoline-media.de/ics/bayern_gf.ics  >> Fetch starts.
              { state: 'renewed',
                lastFetchedTime: '18-09-03 08:52:25',
                lastFetchedEvents: 8,
                lastFetchedOldEvents: 0,
                lastServedEvents: 8,
                error: null }
              Config:
                    //disabled:true,
                      system: {
                        show: ['monthly']
                      views: {
                        monthly: {
                          counts:6
                          url: "http://www.ecoline-media.de/ics/bayern_gf.ics"
              Is there any symptom (eg. error logs) for your issue?
              • V
                Vauxdvihl
                @Sean
                It is strange
                I have copied the file to the system
                Log:
                [CALEXT] http://localhost:8080/modules/bayern_gf.ics  >>
                0|mm       | { state: 'renewed',
                0|mm       |   lastFetchedTime: '18-09-08 09:07:31',
                0|mm       |   lastFetchedEvents: 17,
                0|mm       |   lastFetchedOldEvents: 0,
                0|mm       |   lastServedEvents: 17,
                0|mm       |   error: null }
                Config:
                					url: "http://localhost:8080/modules/bayern_gf.ics",
                					styleName: "style1",
                					symbol: 'de@em',
                				    maxEntries: 50,
                					maxDays:365,
                					interval: 24*60*60*1000,
                But the module will not show the datas in the calendar.
                Other google calendars are shown
                Any idea?
                Thank
                  @vauxdvihl
                  Show me the full config of this module.
                  • V
                    Vauxdvihl
                    @Sean
                    Here u r
                    				position: "lower_third", //anywhere. It is not related to real position of view
                    				config: { // Read below
                    				system: {
                    				  show: [/*'current','upcoming',*/'weeks'],
                    				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                    				  showEmptyView: 0,
                    				  fullDayEventLocalize: 1,
                    				  redrawInterval: 30*60*1000, //minimum 60000
                    				  useProfileConfig: 0,
                    				  startProfile: ''
                    				 views: {
                    						current: {
                    						  position: "top_center",
                    						  title: "Heute",
                    						  limit: 2,
                    						upcoming: {
                    						  title: "Demnächst",
                    						  limit: 2,
                    						weeks: {
                    						  position: "bottom_bar",
                    						  title: "Überblick",
                    						  counts: 2,
                    					symbol: 'de@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					url: "http://localhost:8080/modules/abfallkalender.ics",
                    					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
                    					symbol: 'put_litter_in_its_place@em',
                    					maxEntries: 50,
                    					maxDays:365,
                    					url: "https://calendar.google.com/calendar______",
                    					styleName: "style19",
                    					symbol: 'guitar@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					name: "Familie Warneke",
                    					styleName: "style6",
                    					symbol: 'man-woman-boy-boy@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					url: "https://calendar.google.com/calendar_____",
                    					styleName: "style11",
                    					symbol: 'bike@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					styleName: "style12",
                    					symbol: 'birthday@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					symbol: 'crown@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    					url: "https://calendar.google.com/calendar____",
                    					symbol: 'baby@em',
                    				    maxEntries: 50,
                    					maxDays:365,
                    ? J 2 Replies Last reply Reply Quote 0
                      @vauxdvihl
                      Hmmm, in my memory of last test, there is no event of Byern holiday in September. Your config would show events in 2 weeks. I think it seems to be normal. Isn’t it?
                      • V
                        Vauxdvihl
                        @Sean
                        Sorry no
                        Currently school is out (summer)
                        Starts again on tuesday next week
                        So there should be an entry called “Sommerferien” in the calendar for this week and for next monday.
                        But i will set it like your request
                          @vauxdvihl I’ve found what was wrong and fixed it. sorry. update and try again.
                            SK4018
                            Hi all,
                            stupid question for you guys. How do I update the module? My mirror says I’m behinde two updates. Thanks!
                              A Former User @SK4018
                              @sk4018
                              cd ~/MagicMirror/modules/MMM-CalendarExt
                              git pull
                              • T
                                Tabbe
                                Hi all!
                                Is there way to format the date of current and upcoming views? I used
                                          titleFormat: "dddd",
                                          overTitleFormat : "dddd",
                                But still date format is unchanged.
                                  A Former User @Tabbe
                                  @tabbe
                                  https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#defaultview
                                  Use dateFormat
                                  • T
                                    Tabbe @Guest
                                    @sean said in MMM-CalendarExt:
                                    @tabbe
                                    Use dateFormat
                                    I did try with that but still it remains unchanged.
                                            current: {
                                                            title: "Test",
                                                            dateFormat: "dddd",
                                                            position: 'top_left',
                                                            useRelative: 0,
                                                            limit:2
                                    I also tried without other formating and with basic M.D format.
                                    alt text
                                      @tabbe ‘dddd’ means the weekday name of target date/time. What exactly do you want to display as?
                                      • T
                                        Tabbe @Guest
                                        @sean
                                        I want to display weekday name, like saturday.
                                          @tabbe
                                          I think you’ve missed useRelative field in your config. the default value of useRelative of current & upcoming is 1 or true.
                                          Set it as 0.
                                          upcoming: {
                                                      dateFormat: "dddd",
                                                      timeFormat: "HH:mm",
                                                      limit: 5,
                                                      useRelative: 0
                                          If you want to display only “Saturday” without time, unfortunately it is not supported. (Do you need? e.g. only starting time?)
                                            @tabbe
                                            Now, I’ve updated module to display only starting time.
                                            You can set like this;
                                            upcoming: {
                                                        dateFormat: "dddd",
                                                        timeFormat: " ", // don't use `""` instead `" "`
                                                        limit: 5,
                                                        useRelative: 0,
                                                        onlyStartingTime: 1,
                                            And you can see like this.
                                            • 10
                                            • 5 / 10
