    MMM-CalendarExt
    198 Posts 45 Posters 262.6k Views 45 Watching
      redink
      I am having problems with my mirror, and I can’t figure out which module is the culprit. In my logs, I am seeing something related to this one, so maybe someone could help me out. Any ideas what the error below means?
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | TypeError: Cannot read property 'replace' of null
      0|mm       |     at new Calendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendar.js:38:32)
      0|mm       |     at Calendars.registerCalendar (/home/pi/MagicMirror/modules/MMM-CalendarExt/components/Calendars.js:37:18)
      0|mm       |     at Class.cmd_ADD_CALENDAR (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:45:20)
      0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:36:14)
      0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
      0|mm       |     at emitTwo (events.js:125:13)
      0|mm       |     at Socket.emit (events.js:213:7)
      0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
      0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      • V Offline
        Vauxdvihl
        @Sean
        I have done an update from your module.
        But know the view of my “bank holidays” does not work anymore (the google calender dates are still working fine)
        Can it be that there is some problem accordingly.
        I am using via “webcal” these datas from the following adress:
        www.ecoline-media.de/ics/bayern_gf.ics
        Thanks for you help and your great work
        Cheers
          A Former User @Vauxdvihl
          @vauxdvihl
          In my system, it works.
          Log:
          [CALEXT] http://www.ecoline-media.de/ics/bayern_gf.ics  >> Fetch starts.
          { state: 'renewed',
            lastFetchedTime: '18-09-03 08:52:25',
            lastFetchedEvents: 8,
            lastFetchedOldEvents: 0,
            lastServedEvents: 8,
            error: null }
          Config:
                //disabled:true,
                module: 'MMM-CalendarExt',
                  system: {
                    show: ['monthly']
                  views: {
                    monthly: {
                      counts:6
                      url: "http://www.ecoline-media.de/ics/bayern_gf.ics"
          Is there any symptom (eg. error logs) for your issue?
          • V Offline
            Vauxdvihl
            @Sean
            It is strange
            I have copied the file to the system
            Log:
            [CALEXT] http://localhost:8080/modules/bayern_gf.ics  >>
            0|mm       | { state: 'renewed',
            0|mm       |   lastFetchedTime: '18-09-08 09:07:31',
            0|mm       |   lastFetchedEvents: 17,
            0|mm       |   lastFetchedOldEvents: 0,
            0|mm       |   lastServedEvents: 17,
            0|mm       |   error: null }
            Config:
            					url: "http://localhost:8080/modules/bayern_gf.ics",
            					styleName: "style1",
            					symbol: 'de@em',
            				    maxEntries: 50,
            					maxDays:365,
            					interval: 24*60*60*1000,
            But the module will not show the datas in the calendar.
            Other google calendars are shown
            Any idea?
            Thank
              @vauxdvihl
              Show me the full config of this module.
              • V Offline
                Vauxdvihl
                @Sean
                Here u r
                				position: "lower_third", //anywhere. It is not related to real position of view
                				config: { // Read below
                				system: {
                				  show: [/*'current','upcoming',*/'weeks'],
                				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                				  showEmptyView: 0,
                				  fullDayEventLocalize: 1,
                				  redrawInterval: 30*60*1000, //minimum 60000
                				  useProfileConfig: 0,
                				  startProfile: ''
                				 views: {
                						current: {
                						  position: "top_center",
                						  title: "Heute",
                						  limit: 2,
                						upcoming: {
                						  title: "Demnächst",
                						  limit: 2,
                						weeks: {
                						  position: "bottom_bar",
                						  title: "Überblick",
                						  counts: 2,
                					symbol: 'de@em',
                				    maxEntries: 50,
                					maxDays:365,
                					url: "http://localhost:8080/modules/abfallkalender.ics",
                					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
                					symbol: 'put_litter_in_its_place@em',
                					maxEntries: 50,
                					maxDays:365,
                					url: "https://calendar.google.com/calendar______",
                					styleName: "style19",
                					symbol: 'guitar@em',
                				    maxEntries: 50,
                					maxDays:365,
                					name: "Familie Warneke",
                					styleName: "style6",
                					symbol: 'man-woman-boy-boy@em',
                				    maxEntries: 50,
                					maxDays:365,
                					url: "https://calendar.google.com/calendar_____",
                					styleName: "style11",
                					symbol: 'bike@em',
                				    maxEntries: 50,
                					maxDays:365,
                					styleName: "style12",
                					symbol: 'birthday@em',
                				    maxEntries: 50,
                					maxDays:365,
                					symbol: 'crown@em',
                				    maxEntries: 50,
                					maxDays:365,
                					url: "https://calendar.google.com/calendar____",
                					symbol: 'baby@em',
                				    maxEntries: 50,
                					maxDays:365,
                ? J 2 Replies Last reply Reply Quote 0
                  @vauxdvihl
                  Hmmm, in my memory of last test, there is no event of Byern holiday in September. Your config would show events in 2 weeks. I think it seems to be normal. Isn’t it?
                  • V Offline
                    Vauxdvihl
                    @Sean
                    Sorry no
                    Currently school is out (summer)
                    Starts again on tuesday next week
                    So there should be an entry called “Sommerferien” in the calendar for this week and for next monday.
                    But i will set it like your request
                      @vauxdvihl I’ve found what was wrong and fixed it. sorry. update and try again.
                        SK4018
                        Hi all,
                        stupid question for you guys. How do I update the module? My mirror says I’m behinde two updates. Thanks!
                          A Former User @SK4018
                          @sk4018
                          cd ~/MagicMirror/modules/MMM-CalendarExt
                          git pull
                          • T Offline
                            Tabbe
                            Hi all!
                            Is there way to format the date of current and upcoming views? I used
                                      titleFormat: "dddd",
                                      overTitleFormat : "dddd",
                            But still date format is unchanged.
                              A Former User @Tabbe
                              @tabbe
                              https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#defaultview
                              Use dateFormat
                              • T Offline
                                Tabbe @Guest
                                @sean said in MMM-CalendarExt:
                                @tabbe
                                Use dateFormat
                                I did try with that but still it remains unchanged.
                                        current: {
                                                        title: "Test",
                                                        dateFormat: "dddd",
                                                        position: 'top_left',
                                                        useRelative: 0,
                                                        limit:2
                                I also tried without other formating and with basic M.D format.
                                alt text
                                  @tabbe ‘dddd’ means the weekday name of target date/time. What exactly do you want to display as?
                                  • T Offline
                                    Tabbe @Guest
                                    @sean
                                    I want to display weekday name, like saturday.
                                      @tabbe
                                      I think you’ve missed useRelative field in your config. the default value of useRelative of current & upcoming is 1 or true.
                                      Set it as 0.
                                      upcoming: {
                                                  dateFormat: "dddd",
                                                  timeFormat: "HH:mm",
                                                  limit: 5,
                                                  useRelative: 0
                                      If you want to display only “Saturday” without time, unfortunately it is not supported. (Do you need? e.g. only starting time?)
                                        @tabbe
                                        Now, I’ve updated module to display only starting time.
                                        You can set like this;
                                        upcoming: {
                                                    dateFormat: "dddd",
                                                    timeFormat: " ", // don't use `""` instead `" "`
                                                    limit: 5,
                                                    useRelative: 0,
                                                    onlyStartingTime: 1,
                                        And you can see like this.
                                        • T Offline
                                          Tabbe @Guest
                                          @sean
                                          This is weird. I did update module and still not getting like that.
                                          :~/MagicMirror/modules/MMM-CalendarExt$ git pull
                                          Already up-to-date.
                                          Also, I would like it to be on current since it shows current date event. What I am trying to show is birthdays and suchs.
                                            @tabbe
                                            Hmmm. weird,
                                            As you can see on github page, 40mins ago I updated the module.
                                            And you can use that config in current view also.(above is just sample)
                                            • 10
                                            • 5 / 10
