    MMM-CalendarExt
    198 Posts 45 Posters 257.9k Views 45 Watching
    • cruunnerrC Offline
      cruunnerr
      I realized, that every time the Calendars will be fetched, pm2 creates a log entry in it’s log file.
      Well, sometime the log file will be very big, so my question is if it is necessary or advisable to delete the log file and if there is a way to do that automatically.
      • Y Offline
        yawns Moderator @cruunnerr
        @cruunnerr
        I would try https://github.com/keymetrics/pm2-logrotate/blob/master/README.md for this. Looks like you can set a limit, and pm2 creates a new log file after the limit is reached. You can also activate compression for older log files and define how many old log files you would like to keep.
        But I did not try
          cruunnerr
          @yawns
          Yeah, i saw this already. Unfortunately my english isn’t good enough to understand this :/
          I just create a bash script with following content: pm2 flush
          The script will be executed by a cronjob every sunday at 4am.
          Maybe not the cleanest solution…
          I will take a look again at the log rotate method. :) thanks dude
          • Y Offline
            @cruunnerr
            Understood. If you don’t figure it out I will try when I am back home next weekend
              cruunnerr
              Hey guys,
              I am trying to show the same calendar on “weeks” and on “upcoming” but with different “maxEntries”. Is that possible?
              tried it like this:
                                                      //Muellkalendar
                                                    url: "webcal://p53-calendars.icloud.com/published/2/.....",
                                                    styleName: "style2",
                                                    maxEntries: 20,
                                                    symbol: "delete-empty@md",
                                                    views: ["weeks"],
                                                    interval: 86400000, // 24 Stunden
                                                      //Muellkalendar-Upcoming
                                                    maxEntries: 2,
                                                    views: ["upcoming"],
              But then i get the “create a config” message
                [[global:former-user]] @cruunnerr
                @cruunnerr
                maxEntries is only worked for the count of loading events of calendar, not the view. You can use limit for limitation of the number of events of specific view.
                  cruunnerr
                  Thanks for your reply.
                  I already used limit for the upcoming view. I have 3 calendars in the upcoming view and the limit works fine.
                  But i want to show the same calendar once in the weeks view with up to 20 entries and in the upcoming view max. 2 so the other calendar entries will not be blocked by the calendar i just need 2 entries.
                  anyhow, it seems not to be possible. But thank u anyway. Great module at all :)
                  • MortenVSM Offline
                    MortenVS
                    Thanks a lot for a great module!!!
                    Currently doing my finishing touches on my MagicMirror and CalendarExt.
                    I’m using 1 daily view (bottom_bar) and 2 column view (top_left), each with a dedicated google calendar.
                    Have tried to configure 2 upcoming view, still without any luck.
                    I have 2 questions:
                    1. How can I set up CalendarExt to use 2 upcoming views or reconfigure one of the other views to function and present as the upcoming view?
                      (Preferable without being affected by future updates.)
                    2. Is there any method (or planned feature) to limit my calendars from 3 to 1 by filtering, including or excluding events per view?
                      Example:
                                            title: "Birthdays",
                                            views: ['upcoming'],
                    			includeEvent: ["/Birthday/gi']
                                            url: "https://calendar.google.com/calendar/ical/....",
                                            views: ['daily'],
                    			excludeEvent: ["/Birthday/gi']
                    Hope you can help.
                      [[global:former-user]] @MortenVS
                      @MortenVS
                      1. You cannot use “2 upcoming views” at the same time. sorry. If you use “profile”, you can select or change to show the view from “multi upcoming views”, but not together.
                      2. I hadn’t imagined that kind of function. I think some kind of filtering function would be needed for your purpose. When I have a time, I might add that.
                      • MortenVSM Offline
                        MortenVS
                        Thanks for your update and for considering the feature.
                        Hope to see filtering sometime in the future in this already great module.
                          d3r
                          @Sean
                          Hey, is there a way to rename/hide the location of an event for a specific calendar?
                          Similar to the replaceTitle configuration.
                          Thanks,
                            [[global:former-user]] @d3r
                            @d3r
                            You can hide location by modifying CSS, but no way to rename. You should do it in your feed.
                              simzdk
                              I have a problem that a all day event, also shows up the next day. Have tried both daily and weeks view, and same error.
                              I use locale da-DK
                              N ? 2 Replies Last reply Reply Quote 0
                              • N Offline
                                ninjabreadman @simzdk
                                @simzdk Seems @nn1mda is having the same problem here. @Sean is busy, but maybe we can convince him to have a look. As @modderhut suggests, best to open an issue on Github.
                                  [[global:former-user]] @simzdk
                                  @simzdk
                                  Send me your configuration and ical to test.
                                  My email is in my profile.
                                  And as @ninjabreadman said, I’m so busy to catch up the forum. if you leave your request in Github, I’ll try to support.
                                    simzdk @Guest
                                    @Sean, Thanks!
                                    Email sent!
                                      abetterway
                                      This may be a silly question, but I am pretty new to using git. I am wanting to install this module on a RPI Zero and cannot figure out how to “git clone” the sub tree repository with the RPI 1 compatibility changes.
                                      Is there a way to tell the git to clone from a sub folder/branch?
                                      Thanks!
                                      • N Offline
                                        ninjabreadman @abetterway
                                        @abetterway I think you mean switch the origin branch of the MMM-CalendarExt repository to forRPI1.
                                        In this case, use git checkout forRPI1 within the ~/MagicMirror/modules/MMM-CalendarExt directory.
                                          abetterway
                                          That’s exactly what I needed. Thank you!
                                            ragincajunintx
                                            • 10
                                            • 3 / 10
