    currentweather isn't working
    modulecurrentweatherweather
    7 Posts 7 Posters 3.4k Views 7 Watching
      dustin
      I’m new with this whole MagicMirror thing… So please be patient with me.
      Since I had installed the program, the currentweather module is not working (not displayed when running).
      I also edited the code, but I don’t think that’s the issue. If there is a mistake please correct me.
      What could be the problem?
      Best reguards,
      Dustin
      module: “currentweather”,
      position: “top_right”,
      		locationID: "2945024", //Braunschweig +++Location ID from http://openweathermap.org/help/city_list.txt
      		appid: "abcde12345abcde12345abcde12345ab", //openweathermap.org API key.
      		degreeLabel: "true",
      		updateInterval: "300000",
      		animationSpeed: "500",
      		showWindDirection: "true",
      		useKMPHWind: "true",
      		lang: "de"
      • dimitrigoD Offline
        dimitrigo
        @dustin said in currentweather isn’t working:
        currentweather
        Hello, yes me too.
        I’m too a new user !! ;)
          sefeing
          Seems this is due to : https://forum.magicmirror.builders/topic/6878/changing-units-from-metric-to-imperial-breaks-currentweather-module
          I’m having the same issue.
          • O Offline
            oddswop
            I’m going to assume you have an actual API key and that the one you posted here is just a dummy one… if not… then you need to get an API key from openweathermap.org
            • T Offline
              theMadMaker
              I’m having a similar problem:
              It worked fine on first boot but after I changed “units” in config.js, weatherForecast still works fine but currentWeather doesn’t display.
              • T Offline
                Thelonius
                Me too. Current Weather mod just disappeared after updating mm to latest version.
                  Riotz
                  It would seem that the CurrentWeather module does not like it when you change to imperial units.
