    Slim display due to thin space
    13 Posts 6 Posters 9.9k Views 6 Watching
    • K Offline
      Kastore
      Yeah I know - the 20th or so topic in regards to “monitors/display”. I have however read trough most of them and didnt find an answer to “my” question.
      I am building my MM in a door of a bathroom-closet. That means I only have the thickness of the door to place all the parts in it. Hence I only got about 1,5cm room.
      Now I saw various topics about people saying “take whatever monitor you find”. However the last one I dismantled had the control pannel behind it and was extraordinary thick. So I do not know which monitor is okay or what I have to pay attention to (well besides plugs to the side and downwards)
      So do you guys have any suggestions for a slimmer version of the whole monitor/pannel that a student can afford? ^^’
      The mirror is 45*67 cm - so I got some room to work with in regards to the display-size.
      Thanks in advance and sorry for any spelling/grammar mistakes. English aint my first language.
        albertlwj
        you’re not going to be able to work with 1.5cm room
          d3r
          Maybe look into a laptop screen, though I don’t think you would be able to find one to fit your whole mirror.
          I use my old laptop’s 15.6in screen with a controller board. The screen and controller board are less than 1.5cm thick but the power brick is about 4 cm thick if i recall correctly.
          I never got around to building a frame for it so it just sits on a desk(I don’t use a mirror).
          • K Offline
            Kastore @albertlwj
            @albertlwj
            I have 1.5cm for the monitor and the pi - for power and such i can use the space of the closet itself.
            The questions aims towards if somebody has a “regular monitor” that i could use which isnt as thick.
            @d3r
            Yeah i got my old laptop screen at sitting there with a wrong control panel (wrong panel id on the company homepage) but i was thinking about / hoping for a bigger screen solution
              albertlwj
              why don’t u have a new door rebuilt? the extra space you get would be totally customed to your specs, and it would be much cheaper than obtaining a large screen that’s 1.5cm or less.
              • N Offline
                ninjabreadman @albertlwj
                @Kastore Why not just let the mirror extend past the back of the door? Are there shelves? Just let your mirror wear a backpack.
                Problem with config or JavaScript? Copy/paste it into JSHint.
                Check out the detailed walkthroughs on install, config, modules, etc.
                • K Offline
                  Kastore
                  @albertlwj
                  Not sure if that fixes the problem since i then have a “bigger” door and thus not more space.
                  @ninjabreadman
                  I wanted to keep it “clean” and not have a huge bulky frame behind the door.
                  And yes there a shelves behind the door. So i may have a little bit more space to work with but as mentioned i aim for getting the whole thing “inside” the door
                  I just started working somewhere new and they had monitors that are super thing: LG 24MB56HQ-B. I am trying to find something along that line.
                  Problem with that specific monitor is that they got the plug facing “backwards” and not down :/
                    MadScientist
                    Well, the Raspberry Pi alone is already a fatty with its LAN and USB ports. How will you deal with that? What about the power supply and the heat release? The space you have is tiny. If you every manage to make it fit neatly you should definitely post pictures :-)
                      broberg Project Sponsor
                      Tha panels themselfs usually isn’t as thick as the total monitor, the electronics are the thick parts, some soldering and new cables and you should be able to move it all to the side inside the cabinet
                      • K Offline
                        Kastore @broberg
                        @broberg
                        oh totally forgot that I could do that!! Man… i am an academic and totally lost sight of that solution!
                        I think I have a look at the price of the monitor i found and we see :D
                        • K Offline
                          Kastore
                          Little update on the monitor:
                          I decided to go with a BENQ GL2450 which I found cheap on ebay.
                          And since I was a bit to eager I forgot the “before” picture but amazon does have them :P
                          Well here is the whole monitor dismanteled
                          The pannel itself is the desired 1cm
                          The conductors dont -.-
                          So there goes my “dream” of having nothing showing out of the back… I think I will have to work around it somehow ._.
                            MadScientist
                            You could buy a universal LCD controller board like the V56. Buy the longest LVDS cable you can find. The board itself, w/o LED driver cost around 7.50€-8.00€ incl. shipping. The cheapest LVDS cable I found was 0.88€ incl. shipping. Usually they are around 20cm but you could also make a longer one yourself. A universal LED driver should be less than a euro, too.
                            You could then lead the cables to the inside of the cabinet (via the hinges probably). and hide the electronic boards in a hidden double floor board (if you know what I mean). Like a box inside, or on top of the mirror. Just make sure you allow air flow for cooling.
                            • K Offline
                              Kastore
                              @MadScientist said in Slim display due to thin space:
                              The problem with having it “not mounted” to the door itself will be the cables. I will keep on using the door so id have to make sure they dont break or get stuck or anything.
                              The power cords are strong enough so i dont have to worry - but the LVDS cable i dont trust toooo much ^^
                              I guess i will be building a “box” on the top side of the door and have the whole equipment in there. That way it is “out of sight”, near a hinge and got a low leverage.
                              But I may order one of the universal boards and mount that to the door as well. Just to reduce the size. Very nice tip from you! Didnt know they are SO MUCH THINER! Wish they had used that right away in the BenQ monitor ._.
                              And the air will flow via some airholes on the bottom and top - like a chimney (hope that is enough ^^)
