    Problem to update
    3 Posts 2 Posters 1.8k Views 2 Watching
    • G Offline
      greda
      Hello Everybody,
      I ve got a message on my miroir :
      the current installation is 149 commits late on the master branch
      I try to make update with this command : sudo git pull && npm install in the folder MagiMirror/module but i ve got this message : error: Your local changes to the following files would be overwritten by merge : modules/default/compliments/compliments.js
      Please, commit your changes or stash them before you can merge.
      Aborting
      Thank you for your helping.
        AxLed Module Developer
        Hi greda,
        if you dont need the changes anymore:
        change in the directory (modules/default/compliments in your case)
        git reset --hard
        git pull origin master
        After this, try to update again, you should get further with your update.
        Regards AxLED
        • G Offline
          greda
          Hi AxLED
          Thank you so much nom i ve got update on my MagicMirror.
          Regards Greda
