    Calendar module maxTitleLength is not working
    3 Posts 2 Posters 1.8k Views 2 Watching
    • STRK14S Offline
      STRK14
      Hi !
      So long story short:
      I’m using the default Calendar module. Because I’m using a small display i cannot have long Entries. Therefore i am using “maxTitleLength” but it’s not working…
      This is my configuration:
      			header: "xx",
      				colored: true,
      							url: 'xxxxxxxxxxxxx',
      							symbol: 'graduation-cap',
      							color: "#F05203",
      							maximumEntries: '5',
      							maximumNumberOfDays: '2',
      							maxTitleLength: '10',
      Thank You.. :)
      • yawnsY Offline
        yawns Moderator
        maxTitleLength should be an option inside config, not inside the calendars array. Try moving it to the same level as colored.
        • STRK14S Offline
          STRK14
          Ok that worked, but the Problem changed… now the calendar module is going over my weather modul.
          They are top_left and top_right but they don’t auto adjust… any clue?
