Calendar module maxTitleLength is not working
Hi !
So long story short:
I’m using the default Calendar module. Because I’m using a small display i cannot have long Entries. Therefore i am using “maxTitleLength” but it’s not working…
This is my configuration:{ module: "calendar", header: "xx", position: "top_right", config: { colored: true, calendars: [ { url: 'xxxxxxxxxxxxx', symbol: 'graduation-cap', color: "#F05203", maximumEntries: '5', maximumNumberOfDays: '2', maxTitleLength: '10', }, ], } },``` Thank You.. :) -
maxTitleLengthshould be an option inside config, not inside the calendars array. Try moving it to the same level ascolored. -
Ok that worked, but the Problem changed… now the calendar module is going over my weather modul.
They are top_left and top_right but they don’t auto adjust… any clue?
