    Current Weather do not display
    4 Posts 3 Posters 1.7k Views 2 Watching
      MichaelS
      first, my English is not so good but i try to explain my problem.
      The Weather Forecast do not displayed an i dont know why.
      Here is my confi.js
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "2867714",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "2403028866217760c034e4e08bc4d45a"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "aktuelle Nachrichten",
      						url: "https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html"
      				showSourceTitle: true,
      				showPublishDate: true
      Who can help to fix the problem?
      • C Offline
        Charley Module Developer
        You might need to add the city name
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          MichaelS
          @MichaelS said in Current Weather do not display:
          No, i try it before.
          • Y Offline
            yawns Moderator
            You only load module currentweather and not weatherforecast, so you won’t see any forecast.
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            				appid: "YOUR_OPENWEATHER_API_KEY"
