    Need simple module to switch between 2 texts
    2 Posts 2 Posters 1.3k Views 2 Watching
    • JanneJ
      Janne
      Is there any module where I can write two texts and then the module will switch between the texts every day?
      So if text 1 = ‘Blue’ and text 2 = ‘Yellow’, then the first day MMM will show ‘Blue’ and second day MMM will show ‘Yellow’.
      This should be repeated in an infinity loop.
      As a nice twist it would be even better that if the MMM is restarted it will start at the text that it stopped with.
      MrBorgM 1 Reply Last reply
      • MrBorgM
        MrBorg @Janne
        @janne Not much help in here - Though I could see this as a smart feature where a task can be divided between people. And the task will be assigned to a new person each day. If it was possible to make a file with the assigned person each night (with cron) and then MMM should only show the content of the txt-file. Then the next thing will how to create this cron entry.
