    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    mmm-food2fork-recipes
    Utilities
      spectroman last edited by
      Like to Cook? Like to have different meals everyday? Want to have some inspirational help to think about the food you like?
      Here you can get more inspired to you everyday menu.
      https://github.com/spectroman/mmm-food2fork-recipes
      Get a listing from Food2Fork with a 50px x 50px image – Color images right now.
      Use a different (or whatever you want) search word per week day to find your recipes.
      Get random results.
      N 1 Reply Last reply Reply Quote 1
      • N
        nhl @spectroman last edited by
        @spectroman Works great. Thanks.
        Just a heads up. You have an extra comma in your config example.
          not sure if it makes a whole lot of difference, but I removed one there 😃
          • P
            plumcraft last edited by paviro
            Great idea, works great.
            Sometimes i got this error :
            Uncaught TypeError: Cannot read property 'publisher' of undefined
            Is there an api rate limit ?
            Note from admin: Please use Markdown on code snippets for easier reading!
              spectroman last edited by spectroman
              After creating a login for you at the food2fork, you can get your own API code, the free access will provide 500 requests per day, which is more than enough to run the module nonstop , updating by the hour…
              The APIkey at the example configuration is not for real.
              You can get the key, after register, here: http://food2fork.com/about/api
                And here is an example on how it should look like:
                alt text
                • R
                  reallykeene last edited by
                  Looks as if the website is shut down. May need to revise this module
