    Update Broke it good?
    5 Posts 3 Posters 2.5k Views 3 Watching
      moshinh
      So, I was trying to load my office365 calendar, and it wouldn’t load. Searches led me to believe it was fixed in an update. Sure enough, I hadn’t updated, ever. Started this over a year ago. So I decided to ‘git pull’ and try to launch mirror again. Now it won’t start at all. I get the below.
      Any ideas? Im not that smart really.
      > magicmirror@2.3.1 start /home/pi/MagicMirror
      > sh run-start.sh
      App threw an error during load
      Error: Cannot find module 'express-ipfilter'
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:403:25)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/js/server.js:13:43)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions..js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
      A JavaScript error occurred in the main process
      Uncaught Exception:
        moshinh
        LOL that would explain a lot. helps to install what you’ve downloaded I suppose. Newb of the day? – Thanks!!! I was install each piece off the error message e.g., npm install express-iptables, npm install handle etc etc
        • yawnsY Offline
          yawns Moderator
          You need to run npm install in main MagicMirror folder after git pull
            moshinh
            • ? Offline
              A Former User
              So I went with what I thought I knew.
              Followed the instructions listed here:
              https://stackoverflow.com/questions/42741243/how-do-you-install-newest-version-of-node-js-on-raspberry-pi
              and now I get the below :-(
              Any ideas?
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                  at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                  at Module._compile (internal/modules/cjs/loader.js:678:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:689:10)
                  at Module.load (internal/modules/cjs/loader.js:589:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:528:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:520:3)
                  at Module.require (internal/modules/cjs/loader.js:626:17)
                  at require (internal/modules/cjs/helpers.js:20:18)
                  at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.3.1 start script.
              npm ERR!     /home/pi/.npm/_logs/2018-05-09T16_16_54_422Z-debug.log
                moshinh
                This post is deleted!
