    Installing USB Soundcard using seperate USB Mic
    12 Posts 3 Posters 9.8k Views 3 Watching
    • MrCoffeeM Offline
      MrCoffee
      I use a Pi 3 with jessie.
      My Monitor doesn´t have HDMI thats why I use the audio jack of the Pi to play sound to the monitor speakers.
      Additionaly I use a usb mic.
      This setting works fine, but the audio out is very silent. Thats why I want to add a usb soundcard (just for audio out).
      And here my problem starts. The Pi always plays sound over the audio jack. No matter what.
      I already spended hours searching the internet and trying different thinks.
      Here are some outputs:
      lsusb:
      Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
      Bus 001 Device 005: ID 0d8c:0014 C-Media Electronics, Inc.
      Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
      Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      It is Device 5.
      aplay -l:
      **** Liste der Hardware-Geräte (PLAYBACK) ****
      Karte 0: Device_1 [USB Audio Device], Gerät 0: USB Audio [USB Audio]
        Sub-Geräte: 1/1
        Sub-Gerät #0: subdevice #0
      Karte 2: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
        Sub-Geräte: 8/8
        Sub-Gerät #1: subdevice #1
        Sub-Gerät #2: subdevice #2
        Sub-Gerät #3: subdevice #3
        Sub-Gerät #4: subdevice #4
        Sub-Gerät #5: subdevice #5
        Sub-Gerät #6: subdevice #6
        Sub-Gerät #7: subdevice #7
      Karte 2: ALSA [bcm2835 ALSA], Gerät 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
        Sub-Geräte: 1/1
      arecord -l:
      **** Liste der Hardware-Geräte (CAPTURE) ****
        Sub-Geräte: 1/1
      Karte 1: Device [USB PnP Sound Device], Gerät 0: USB Audio [USB Audio]
        Sub-Geräte: 0/1
      So, card 0 aka Device_1 is my usb soundcard and card 1 aka Device is my microphone.
      cat /proc/asound/modules:
      0 snd_usb_audio
      1 snd_usb_audio
      2 snd_bcm2835
      I didn´t touch the configuration but both usb´s are starting before the internal soundcard.
      I tried different /etc/asound.conf, for expample:
      #defaults.ctl.card 0
      #defaults.pcm.card 0
      pcm.!default {
          type asym
          playback.pcm "plughw:Device_1"
          capture.pcm  "plughw:Device"
      or
      pcm.!default {
        type asym
         playback.pcm {
           type plug
           slave.pcm "hw:0,0"
         capture.pcm {
           type plug
           slave.pcm "hw:1,0"
      I even edited the default devices in the /usr/share/alsa/alsa.conf.
      No luck at all.
      I am thankful for every help.
      • N Offline
        NoNameRo @MrCoffee
        @mrcoffee
        give it a try
        pcm.!default {
          type asym
          capture.pcm "mic"
          playback.pcm "speaker"
        pcm.mic {
          type plug
          slave {
            pcm "hw:0,0"
        pcm.speaker {
          type plug
          slave {
            pcm "hw:0,0"
        or
        pcm.!default {
          type asym
          capture.pcm "mic"
        pcm.mic {
          type plug
          slave {
            pcm "hw:0,0"
        pcm.speaker {
          type plug
          slave {
            pcm "hw:1,0"
        then restart with sudo /etc/init.d/alsa-utils restart
        under alsamixer can still adjust the volume level
        MrCoffeeM 1 Reply Last reply Reply Quote 0
        • MrCoffeeM Offline
          MrCoffee @NoNameRo
          @NoNameRo
          Thank you for your fast response.
          Unfortunately it is still not working. I tried both versions and restarted with the command you told me.
          I even rebootet just to be sure.
          What I didnt do is switching the cable from jack to the usb soundcard, because it is late and the mirror on the wall again. But I expect, that it would be mute if it works, right?
          I forgot to write above, that I can see all 3 devices in the alsamixer.
          • E Offline
            E3V3A @MrCoffee
            @mrcoffee
            I have seen solutions to this here: https://raspberrypi.stackexchange.com
            search there.
            Also, only use ONE sound card for AUX (ouput) and MIC (input). Otherwise you will get confused and so your Pie will be unhappy too. It is also highly recommended to disable the internal broadcom sound card when using a USB card. That you can do in the boot config IIRC.
            “Everything I do (here) is for free – altruism is the way!”
            MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
            • MrCoffeeM Offline
              MrCoffee @E3V3A
              @e3v3a
              Now it is getting weired.
              I disabled the internal broadcom by adding it to the blacklist:
              sudo tee /etc/modprobe.d/blacklist-snd_bcm2835.conf
              blacklist snd_bcm2835
              After reboot it is correctly not shown again:
              aplay -l
                Sub-Geräte: 1/1
              But if I start playing a media, the sound still comes from the audio jack.
              How can that be?
              • E Offline
                E3V3A
                dtparam=audio=off
                MrCoffeeM 2 Replies Last reply Reply Quote 0
                • MrCoffeeM Offline
                  MrCoffee @E3V3A
                  @e3v3a
                  Thanks for the help.
                  I didn´t tried it yet because meanwhile my mic has some problems too. The “beep” from Alexa ist still there but sounds already not round. After that the mic does not react at all.
                  Guess I will reset the whole system. Unfortunately I did not have a backup.
                  By the way: If anybody of you knows a raspberry backup programm which I can use under windows please let me know.
                  I will inform you when I reseted my system.
                  • E Offline
                    E3V3A
                    @MrCoffee I don’t think resetting it is gonna be helpful, unless you know you have installed a bunch of other apt packages, and messed with system settings without writing down what you did.
                    • E Offline
                      E3V3A @MrCoffee
                      @mrcoffee
                      Try this: https://github.com/shivasiddharth/GassistPi/tree/master/audio-drivers/USB-MIC-JACK/scripts
                      • MrCoffeeM Offline
                        MrCoffee @E3V3A
                        @E3V3A
                        Hi, I tried the steps from “cloning” to "sudo /home/pi/GassistPi/audio-drivers/USB-MIC-JACK/scripts/usb-mic-onboard-jack.sh " (I have got Alexa not google assistant;-))
                        The alexa beep sounds normal again, but after that there is silence. And I can still force the beep only once per reboot.
                        • MrCoffeeM Offline
                          MrCoffee @E3V3A
                          @e3v3a said in Installing USB Soundcard using seperate USB Mic:
                          dtparam=audio=off
                          I just tried it. Unfortunately with no luck.
                          Sound still comes from the audio jack.
                          • MrCoffeeM Offline
                            MrCoffee
                            I reinstalled the whole system using another SD-card.
                            Now I can use the seperate USB-Mic and the audio Out comes from the other USB-Soundcard.
                            After that I installed all my modules like MMM-Podcast.
                            I played the video and … sound comes from the audio jack again:-(
                            However the usb mic and alexa are still working fine. It is just MMM-Podcast which uses the audio jack.
                            How can that be? I installed the dependecies especially the omxplayer. But that can´t be the reason, or what do you think?
                            lsusb
                            Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
                            aplay -l
                              Sub-Geräte: 1/1
                            sudo nano ~/.asoundrc
                            pcm.!default {
                                type asym
                                playback.pcm "plughw:0"
                                capture.pcm  "plughw:1"
                            ctl.!default {
                                    type hw
                                    card 0
                            Do you have an idea? Seems like I am almost there.
                            Thanks.
