    Module Position
    34 Posts 5 Posters 17.8k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @maxbachmann
      @maxbachmann If you create a github repo, than I can make suggestions what you could improve
        maxbachmann
        @strawberry-3-141 I will when I finished, but have to do some other stuff for the speech recognition first. Will let you know when I posted it on github
          @maxbachmann you dont need to wait until its finished, git is a version control, so it should be used as early as possible.
            maxbachmann
            @strawberry-3-141 yes but I will probably use the voice control in a different way than I hought I would. Thats why I am not sure how I will change the code. Makes not much sence to waste your time on correcting the faults when I change pretty much every part of the program again right afterwards (and have to get used to git since I did not use it yet)
            • 4 / 4
