Module Position
34 Posts 5 Posters 14.9k Views 4 Watching
    maxbachmann
    @strawberry-3-141 and where to add that? is that already the “end code”? I tried in the domupdate function and it did not work, so I guess that was wrong
      it is safe to always run the code so you don’t need to check if there is a module necessarily.
      it is not related to the get dom function, you can put it where ever you want except node_helper (because its not executed in the browser)
      can you post the code of your module or upload it to github, then i can have a look
        maxbachmann
        In general I want to add it to all kind of modules so I can change the position when sending them a socketmessage to do so
        S 1 Reply Last reply May 17, 2018, 6:22 PM Reply Quote 0
          strawberry 3.141 Project Sponsor Module Developer @maxbachmann
          @maxbachmann i wouldn’t place that code in other modules, you can perform that from your module for every module, this isn’t magicmirror related. its pure dom manipulation.
            maxbachmann
            Ah did not know that ;) well yes then it’s definetly in my program. All my program does so far is subscribe to a mqtt broker, load some data and according to this show/hide modules. Now I want to add the possibility to move modules to different positions.
            Can send the current code later
            M 1 Reply Last reply May 17, 2018, 6:32 PM Reply Quote 0
              maxbachmann @maxbachmann
              @strawberry-3-141 so in general use all 3 commands and then it works in both senarios? where can I find the right ID for each module?
              S 1 Reply Last reply May 17, 2018, 6:46 PM Reply Quote 0
                @maxbachmann you can get all modules https://github.com/MichMich/MagicMirror/tree/master/modules#module-selection then iterate over them and when you find the module execute the cmds
                const moduleToMove = 'clock';
                const targetRegion = 'top.left';
                MM.getModules().enumerate((module) => {
                    if (module.name === moduleToMove) {
                        const instance = document.getElementById(module.identifier);
                        const region = document.querySelector(`div.region.${targetRegion} div.container`);
                        region.appendChild(instance);
                        region.style.display = 'block';
                something similar to this
                  maxbachmann
                  @strawberry-3-141 ty that works.
                  Added the possibility
                  region.insertBefore(instance, region.childNodes[0])
                  so I can prepend and append the module
                    justjim1220 Module Developer @maxbachmann
                    @maxbachmann
                    If you look in your css folder you will find the main.css file. Open it and you will find all the regions. Compare them to where you have you modules set and it should help you figure it out.
                    Jim Hallock - 1995
                    M 1 Reply Last reply May 17, 2018, 9:39 PM Reply Quote 0
                      maxbachmann @justjim1220
                      @justjim1220 it already works the way @strawberry-3-141 proposed :)
                      Only thing I am not quite sure about yet is when can I use const?
                      I have the code in socketmessagereceived. Can I use const in there when I do only give the variable one value each time it runs the function? Because for me it seems like the variables still exist when the function gets called again which would mean const does not work
                      J 1 Reply Last reply May 17, 2018, 9:41 PM Reply Quote 0
                      • 2 / 4
                      2 / 4
