    MMM-Assistant "node google-auth.js" error
    1 Posts 1 Posters 852 Views 1 Watching
    • U Offline
      umeeq
      I’m trying to set up MMM-Assistant on my mirror and keep coming across the same issue. I am so close, but whenever I enter…
      node google-auth.js
      …I get the error below. What am I missing? It looks like it can’t locate “google -client-secret.json” but I don’t see a step anywhere where that should have been created.
      node google-auth.js
      internal/modules/cjs/loader.js:550
          throw err;
      Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/assets/google-client-secret.json'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
          at Function.Module._load (internal/modules/cjs/loader.js:475:25)
          at Module.require (internal/modules/cjs/loader.js:598:17)
          at require (internal/modules/cjs/helpers.js:11:18)
          at new Auth (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/components/auth.js:26:15)
          at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/index.js:21:16)
          at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/scripts/google-auth.js:25:19)
          at Module._compile (internal/modules/cjs/loader.js:654:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
      Thanks for all your help.
