Changing icons of the modules Current Weather and Weather Forecast
@sdetweil sorry for not responding to you more quickly, but I had an appointment with the doctor, is it the weather module that doesn’t have the right version? you ask me to use your script but I don’t know what it is, sorry for my ignorance
@Manu85 no problem… I don’t expect any timeline in responses… life goes on
i provide scripts to handle the install and upgrade of the MM base
(these are listed in the MM install doc, alternative approaches)upgrade is a 2 part process, cause I don’t want to destroy you MagicMirror installation
so the first pass is a test… no changes are made… it will tell you anything about the install that might be of concern… (people change files, and do things I don’t know, so check and report… )
then you run again, with a parameter to DO the upgrade…
both are logged, so we can tell what happened.
and I also provide scripts to take and restore backups of the MM installation
which can also be versioned(with git) and saved/restored from github
https://github.com/sdetweil/MagicMirror-backup-restore -
@Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
modules can check the version of MM and fail if its not at least this minimum
https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties(from another module on my system currently)
requiresVersion: "2.1.0",so this one should have had
requiresVersion: "2.26.0", -
@sdetweil ok, I’ll try to see with the link you sent me “https://github.com/sdetweil/MagicMirror_scripts” I hope I won’t break everything
thats why the test mode
@sdetweil ok, I’ll see if I can do it…
@Manu85 and its not fatal… there is some command work to go back to a prior release in place, but possible…
@sdetweil ok so I’m going to pass the command line:
bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)" -
@Manu85 that is install from nothing , not upgrade to newer release
please translate the page if english is not your primary language
@sdetweil fortunately I haven’t taken it yet, I’m starting well…and yes I will translate, thank you
