    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 yep…
      yes the module has been updated since v 2.25,
      (it should have had a version check!, rather than fail like this)
      to use the internal fetch function instead of an external library.
      and u are on 2.23
      use my upgrade script to get to latest 2.26
        Manu85 @sdetweil
        @sdetweil sorry for not responding to you more quickly, but I had an appointment with the doctor, is it the weather module that doesn’t have the right version? you ask me to use your script but I don’t know what it is, sorry for my ignorance
          sdetweil @Manu85
          @Manu85 no problem… I don’t expect any timeline in responses… life goes on
          i provide scripts to handle the install and upgrade of the MM base
          (these are listed in the MM install doc, alternative approaches)
          upgrade is a 2 part process, cause I don’t want to destroy you MagicMirror installation
          so the first pass is a test… no changes are made… it will tell you anything about the install that might be of concern… (people change files, and do things I don’t know, so check and report… )
          then you run again, with a parameter to DO the upgrade…
          both are logged, so we can tell what happened.
          and I also provide scripts to take and restore backups of the MM installation
          which can also be versioned(with git) and saved/restored from github
          https://github.com/sdetweil/MagicMirror-backup-restore
            sdetweil @Manu85
            @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
            modules can check the version of MM and fail if its not at least this minimum
            https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
            (from another module on my system currently)
            requiresVersion: "2.1.0",
            so this one should have had
            requiresVersion: "2.26.0",
              Manu85 @sdetweil
              @sdetweil ok, I’ll try to see with the link you sent me “https://github.com/sdetweil/MagicMirror_scripts” I hope I won’t break everything
                sdetweil @Manu85
                thats why the test mode
                  Manu85 @sdetweil
                  @sdetweil ok, I’ll see if I can do it…
                    sdetweil @Manu85
                    @Manu85 and its not fatal… there is some command work to go back to a prior release in place, but possible…
                      Manu85 @sdetweil
                      @sdetweil ok so I’m going to pass the command line:
                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                        sdetweil @Manu85
                        @Manu85 that is install from nothing , not upgrade to newer release
                        please translate the page if english is not your primary language
                          Manu85 @sdetweil
                          @sdetweil fortunately I haven’t taken it yet, I’m starting well…and yes I will translate, thank you
                            sdetweil @Manu85
                            @Manu85 it’s ok, install again will not do it… checks and exits
                              Manu85 @sdetweil
                              @sdetweil ok, so I pass this line in putty
                              upgrade-script.sh
                              if so do I have to be in the MM folder or at the base of the pi?
                                Manu85 @sdetweil
                                @sdetweil if so do I have to be in the MM folder or at the base of the pi?
                                  sdetweil @Manu85
                                  it has to be the entire line. just push the copy icon that appears when your mouse is over the line in the GitHub content
                                  the script figures it all out
                                    Manu85 @sdetweil
                                    @sdetweil This is the command:
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                      sdetweil @Manu85
                                      @Manu85 yes, that is the 1st test, test run
                                        Manu85 @sdetweil
                                        @sdetweil ok I do it
                                          Manu85 @sdetweil
                                          @sdetweil I say yes or no?
                                            sdetweil @Manu85
                                            @Manu85 well, you have 3 files of ours that will be changed
                                            main.css
                                            and weather.js and calendar.js
                                            those changes will be lost, unless you know what you changed and why…
                                            in general you NEVER edit any of our files…
                                            ALL config goes in config.js
                                            ALL css goes in custom.css
                                            reply no… also, I am adding a new check in test run mode…
                                            these changed files is the EXACT reason for test mode.
                                            otherwise those changes would be lost and your mirror might be broken
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
