    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 that is install from nothing , not upgrade to newer release
      please translate the page if english is not your primary language
      M 1 Reply Last reply
        Manu85 @sdetweil
        @sdetweil fortunately I haven’t taken it yet, I’m starting well…and yes I will translate, thank you
          sdetweil @Manu85
          @Manu85 it’s ok, install again will not do it… checks and exits
          M 2 Replies Last reply
            Manu85 @sdetweil
            @sdetweil ok, so I pass this line in putty
            upgrade-script.sh
            if so do I have to be in the MM folder or at the base of the pi?
              Manu85 @sdetweil
              @sdetweil if so do I have to be in the MM folder or at the base of the pi?
                sdetweil @Manu85
                it has to be the entire line. just push the copy icon that appears when your mouse is over the line in the GitHub content
                the script figures it all out
                  Manu85 @sdetweil
                  @sdetweil This is the command:
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                    sdetweil @Manu85
                    @Manu85 yes, that is the 1st test, test run
                      Manu85 @sdetweil
                      @sdetweil ok I do it
                        Manu85 @sdetweil
                        @sdetweil I say yes or no?
                          sdetweil @Manu85
                          @Manu85 well, you have 3 files of ours that will be changed
                          main.css
                          and weather.js and calendar.js
                          those changes will be lost, unless you know what you changed and why…
                          in general you NEVER edit any of our files…
                          ALL config goes in config.js
                          ALL css goes in custom.css
                          reply no… also, I am adding a new check in test run mode…
                          these changed files is the EXACT reason for test mode.
                          otherwise those changes would be lost and your mirror might be broken
                            Manu85 @sdetweil
                            @sdetweil I may have moved something before meeting you, but in any case, I didn’t do anything that was important, now I know that I only touch config.js and css.custom!
                            to carry out a test I pass the same line?
                              sdetweil @Manu85
                              @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                              you just DID the test pass…
                              if you want to see what changed in those files , for each do
                              git diff thefilename
                              for example
                              git diff css/main.css
                                Manu85 @sdetweil
                                @sdetweil I certainly didn’t understand…when I place the order I get this
                                pi@MagicMirror:~ $ git diff css/main.css
                                Not a git repository
                                To compare two paths outside a working tree:
                                usage: git diff [--no-index] <path> <path>
                                  sdetweil @Manu85
                                  @Manu85 again have to be IN the MagicMirror folder
                                    Manu85 @sdetweil
                                    @sdetweil I think it’s because I wasn’t in the MM folder, now I have this
                                      sdetweil @Manu85
                                      @Manu85 red is old, green is new…
                                      SO, if you want to KEEP those, then they have to move to custom.css
                                      do the same for the other files… needs the full path
                                      modules/default…
                                        Manu85 @sdetweil
                                        @sdetweil ok if I understand correctly, I do this for all modules which presented a problem, putting the full address for each module? example :
                                        git diff modules/default/calendar/calendar.js
                                        , I just
                                          sdetweil @Manu85
                                          @Manu85 yes
                                            Manu85 @sdetweil
                                            @sdetweil ok, I do it you are too strong
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
