    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil I say yes or no?
        sdetweil @Manu85
        @Manu85 well, you have 3 files of ours that will be changed
        main.css
        and weather.js and calendar.js
        those changes will be lost, unless you know what you changed and why…
        in general you NEVER edit any of our files…
        ALL config goes in config.js
        ALL css goes in custom.css
        reply no… also, I am adding a new check in test run mode…
        these changed files is the EXACT reason for test mode.
        otherwise those changes would be lost and your mirror might be broken
        M 1 Reply Last reply
          Manu85 @sdetweil
          @sdetweil I may have moved something before meeting you, but in any case, I didn’t do anything that was important, now I know that I only touch config.js and css.custom!
          to carry out a test I pass the same line?
            sdetweil @Manu85
            @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
            you just DID the test pass…
            if you want to see what changed in those files , for each do
            git diff thefilename
            for example
            git diff css/main.css
              Manu85 @sdetweil
              @sdetweil I certainly didn’t understand…when I place the order I get this
              pi@MagicMirror:~ $ git diff css/main.css
              Not a git repository
              To compare two paths outside a working tree:
              usage: git diff [--no-index] <path> <path>
                sdetweil @Manu85
                @Manu85 again have to be IN the MagicMirror folder
                  Manu85 @sdetweil
                  @sdetweil I think it’s because I wasn’t in the MM folder, now I have this
                    sdetweil @Manu85
                    @Manu85 red is old, green is new…
                    SO, if you want to KEEP those, then they have to move to custom.css
                    do the same for the other files… needs the full path
                    modules/default…
                      Manu85 @sdetweil
                      @sdetweil ok if I understand correctly, I do this for all modules which presented a problem, putting the full address for each module? example :
                      git diff modules/default/calendar/calendar.js
                      , I just
                        sdetweil @Manu85
                        @Manu85 yes
                        M 2 Replies Last reply
                          Manu85 @sdetweil
                          @sdetweil ok, I do it you are too strong
                            Manu85 @sdetweil
                            @sdetweil for calendar I got this return and the cursor did not return to cd ~/MagicMirror/ I just have two points at the bottom of the file
                            pi@MagicMirror:~/MagicMirror $ git diff modules/default/calendar/calendar.js
                            diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/cal        endar.js
                            index 2ef9ca9c..4f70a1e9 100644
                            --- a/modules/default/calendar/calendar.js
                            +++ b/modules/default/calendar/calendar.js
                            @@ -1,6 +1,6 @@
                             /* global cloneObject */
                            -/* MagicMirror²
                            +/* Magic Mirror
                              * Module: Calendar
                              * By Michael Teeuw https://michaelteeuw.nl
                            @@ -11,11 +11,8 @@ Module.register("calendar", {
                                    defaults: {
                                            maximumEntries: 10, // Total Maximum Entries
                                            maximumNumberOfDays: 365,
                            -               limitDays: 0, // Limit the number of days shown, 0 = no limit
                            -               pastDaysCount: 0,
                                            displaySymbol: true,
                            -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https:/        /fontawesome.com/cheatsheet?from=io
                            -               defaultSymbolClassName: "fas fa-fw fa-",
                            :...skipping...
                            diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/calendar.js
                            @@ -1,6 +1,6 @@
                            -/* MagicMirror²
                            +/* Magic Mirror
                              * Module: Calendar
                                    defaults: {
                            -               pastDaysCount: 0,
                            -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                            +               defaultSymbol: "calendar", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                            showLocation: false,
                                            displayRepeatingCountTitle: false,
                                            defaultRepeatingCountTitle: "",
                            @@ -27,25 +24,23 @@ Module.register("calendar", {
                                            maxEventTitleLines: 3,
                                            fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                            animationSpeed: 2000,
                            -               fade: true,
                            +               fade: false,
                                            urgency: 7,
                            -               timeFormat: "relative",
                            -               dateFormat: "MMM Do",
                            +               timeFormat: "absolute",
                            +               dateFormat: "Do MMM HH:mm",
                                            dateEndFormat: "LT",
                            -               fullDayEventDateFormat: "MMM Do",
                            +               fullDayEventDateFormat: "Do MMM",
                                            showEnd: false,
                                            getRelative: 6,
                                            fadePoint: 0.25, // Start on 1/4th of the list.
                                            hidePrivate: false,
                                            hideOngoing: false,
                            -               hideTime: false,
                            -               showTimeToday: false,
                                            colored: false,
                            -               customEvents: [], // Array of {keyword: "", symbol: "", color: ""} where Keyword is a regexp and symbol/color are to be applied for matched
                            +               coloredSymbolOnly: false,
                                            tableClass: "small",
                            -                               symbol: "calendar-alt",
                            +                               symbol: "calendar",
                                                            url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                            @@ -60,18 +55,9 @@ Module.register("calendar", {
                                            excludedEvents: [],
                                            sliceMultiDayEvents: false,
                                            broadcastPastEvents: false,
                            -               nextDaysRelative: false,
                              sdetweil @Manu85
                              @Manu85 all of those changes need to go in config.js
                              (ps, THIS is why you don’t change our files… )
                              and THIS is why test mode… so you have a chance to save your stuff.
                              and AFTER these changes are in config.js , and custom.css
                              AND you tested,
                              THEN u restore the original file
                              and TEST AGAIN… to make sure everything is right.
                              THEN you can upgrade… and these files will all have been restored
                              and won’t show in the changed list (I would run test mode over and over til these problems go away)
                                Manu85 @sdetweil
                                @sdetweil yes, now thanks to you I understand the importance of js and css files
                                  Manu85 @sdetweil
                                  @sdetweil So I have to make the corrections manually in the files concerned by replacing the red lines with green lines, is that it?
                                    sdetweil @Manu85
                                    @Manu85 you don’t have to correct the files… , just move the changes (green) to config.js and custom.css
                                    to restore a file to its release level content do
                                    ~/MagicMirror
                                    git checkout full_path_and_filename
                                    example
                                    git checkout css/main.css
                                    this will restore the file from the local (hidden) source repository
                                    dont do this til you have at least tested once for each file changed…
                                    and you MAY want to copy the affected file to a saved version (add .save to its filename)
                                    in case you missed one of the changes after you restore the file…
                                    M 3 Replies Last reply
                                      Manu85 @sdetweil
                                      @sdetweil I’m trying to understand and I’m having a lot of trouble, in the following example, I haven’t touched anything (I’m almost sure) and I have two lines, the first in red and the second in Green:
                                      -/* MagicMirror²
                                      +/* Magic Mirror
                                      I can’t put the green line in my js.config file, right?
                                      I’m sorry but I’m trying to understand
                                      @@ -1,6 +1,6 @@
                                      -/* MagicMirror²
                                      +/* Magic Mirror
                                        * Module: Calendar
                                        Manu85 @sdetweil
                                        @sdetweil another example that bothers me
                                          Manu85 @sdetweil
                                          @sdetweil one last one for which I don’t know what to do either, thank you again for your help
                                            sdetweil @Manu85
                                            @Manu85 not the -lock.json files , these are generated by npm install
                                            the MagicMirror thing is inside a comment, so not important.
                                            the default symbol, the green goes in config.js for the calendar module. don’t worry about the red
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
