    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil ok, so I pass this line in putty
      upgrade-script.sh
      if so do I have to be in the MM folder or at the base of the pi?
        Manu85 @sdetweil
        @sdetweil if so do I have to be in the MM folder or at the base of the pi?
          sdetweil @Manu85
          it has to be the entire line. just push the copy icon that appears when your mouse is over the line in the GitHub content
          the script figures it all out
            Manu85 @sdetweil
            @sdetweil This is the command:
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              sdetweil @Manu85
              @Manu85 yes, that is the 1st test, test run
                Manu85 @sdetweil
                @sdetweil ok I do it
                  Manu85 @sdetweil
                  @sdetweil I say yes or no?
                    sdetweil @Manu85
                    @Manu85 well, you have 3 files of ours that will be changed
                    main.css
                    and weather.js and calendar.js
                    those changes will be lost, unless you know what you changed and why…
                    in general you NEVER edit any of our files…
                    ALL config goes in config.js
                    ALL css goes in custom.css
                    reply no… also, I am adding a new check in test run mode…
                    these changed files is the EXACT reason for test mode.
                    otherwise those changes would be lost and your mirror might be broken
                      Manu85 @sdetweil
                      @sdetweil I may have moved something before meeting you, but in any case, I didn’t do anything that was important, now I know that I only touch config.js and css.custom!
                      to carry out a test I pass the same line?
                        sdetweil @Manu85
                        @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                        you just DID the test pass…
                        if you want to see what changed in those files , for each do
                        git diff thefilename
                        for example
                        git diff css/main.css
                          Manu85 @sdetweil
                          @sdetweil I certainly didn’t understand…when I place the order I get this
                          pi@MagicMirror:~ $ git diff css/main.css
                          Not a git repository
                          To compare two paths outside a working tree:
                          usage: git diff [--no-index] <path> <path>
                            sdetweil @Manu85
                            @Manu85 again have to be IN the MagicMirror folder
                              Manu85 @sdetweil
                              @sdetweil I think it’s because I wasn’t in the MM folder, now I have this
                                sdetweil @Manu85
                                @Manu85 red is old, green is new…
                                SO, if you want to KEEP those, then they have to move to custom.css
                                do the same for the other files… needs the full path
                                modules/default…
                                  Manu85 @sdetweil
                                  @sdetweil ok if I understand correctly, I do this for all modules which presented a problem, putting the full address for each module? example :
                                  git diff modules/default/calendar/calendar.js
                                  , I just
                                    sdetweil @Manu85
                                    @Manu85 yes
                                      Manu85 @sdetweil
                                      @sdetweil ok, I do it you are too strong
                                        Manu85 @sdetweil
                                        @sdetweil for calendar I got this return and the cursor did not return to cd ~/MagicMirror/ I just have two points at the bottom of the file
                                        pi@MagicMirror:~/MagicMirror $ git diff modules/default/calendar/calendar.js
                                        diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/cal        endar.js
                                        index 2ef9ca9c..4f70a1e9 100644
                                        --- a/modules/default/calendar/calendar.js
                                        +++ b/modules/default/calendar/calendar.js
                                        @@ -1,6 +1,6 @@
                                         /* global cloneObject */
                                        -/* MagicMirror²
                                        +/* Magic Mirror
                                          * Module: Calendar
                                          * By Michael Teeuw https://michaelteeuw.nl
                                        @@ -11,11 +11,8 @@ Module.register("calendar", {
                                                defaults: {
                                                        maximumEntries: 10, // Total Maximum Entries
                                                        maximumNumberOfDays: 365,
                                        -               limitDays: 0, // Limit the number of days shown, 0 = no limit
                                        -               pastDaysCount: 0,
                                                        displaySymbol: true,
                                        -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https:/        /fontawesome.com/cheatsheet?from=io
                                        -               defaultSymbolClassName: "fas fa-fw fa-",
                                        :...skipping...
                                        diff --git a/modules/default/calendar/calendar.js b/modules/default/calendar/calendar.js
                                        @@ -1,6 +1,6 @@
                                        -/* MagicMirror²
                                        +/* Magic Mirror
                                          * Module: Calendar
                                                defaults: {
                                        -               pastDaysCount: 0,
                                        -               defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                        +               defaultSymbol: "calendar", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                                        showLocation: false,
                                                        displayRepeatingCountTitle: false,
                                                        defaultRepeatingCountTitle: "",
                                        @@ -27,25 +24,23 @@ Module.register("calendar", {
                                                        maxEventTitleLines: 3,
                                                        fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                        animationSpeed: 2000,
                                        -               fade: true,
                                        +               fade: false,
                                                        urgency: 7,
                                        -               timeFormat: "relative",
                                        -               dateFormat: "MMM Do",
                                        +               timeFormat: "absolute",
                                        +               dateFormat: "Do MMM HH:mm",
                                                        dateEndFormat: "LT",
                                        -               fullDayEventDateFormat: "MMM Do",
                                        +               fullDayEventDateFormat: "Do MMM",
                                                        showEnd: false,
                                                        getRelative: 6,
                                                        fadePoint: 0.25, // Start on 1/4th of the list.
                                                        hidePrivate: false,
                                                        hideOngoing: false,
                                        -               hideTime: false,
                                        -               showTimeToday: false,
                                                        colored: false,
                                        -               customEvents: [], // Array of {keyword: "", symbol: "", color: ""} where Keyword is a regexp and symbol/color are to be applied for matched
                                        +               coloredSymbolOnly: false,
                                                        tableClass: "small",
                                        -                               symbol: "calendar-alt",
                                        +                               symbol: "calendar",
        url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                        @@ -60,18 +55,9 @@ Module.register("calendar", {
                                                        excludedEvents: [],
                                                        sliceMultiDayEvents: false,
                                                        broadcastPastEvents: false,
                                        -               nextDaysRelative: false,
                                          sdetweil @Manu85
                                          @Manu85 all of those changes need to go in config.js
                                          (ps, THIS is why you don’t change our files… )
                                          and THIS is why test mode… so you have a chance to save your stuff.
                                          and AFTER these changes are in config.js , and custom.css
                                          AND you tested,
                                          THEN u restore the original file
                                          and TEST AGAIN… to make sure everything is right.
                                          THEN you can upgrade… and these files will all have been restored
                                          and won’t show in the changed list (I would run test mode over and over til these problems go away)
                                            Manu85 @sdetweil
                                            @sdetweil yes, now thanks to you I understand the importance of js and css files
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
