    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
      s it the weather module that doesn’t have the right version?
      modules can check the version of MM and fail if its not at least this minimum
      https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
      (from another module on my system currently)
      requiresVersion: "2.1.0",
      so this one should have had
      requiresVersion: "2.26.0",
        Manu85 @sdetweil
        @sdetweil ok, I’ll try to see with the link you sent me “https://github.com/sdetweil/MagicMirror_scripts” I hope I won’t break everything
          sdetweil @Manu85
          thats why the test mode
            Manu85 @sdetweil
            @sdetweil ok, I’ll see if I can do it…
              sdetweil @Manu85
              @Manu85 and its not fatal… there is some command work to go back to a prior release in place, but possible…
                Manu85 @sdetweil
                @sdetweil ok so I’m going to pass the command line:
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                  sdetweil @Manu85
                  @Manu85 that is install from nothing , not upgrade to newer release
                  please translate the page if english is not your primary language
                    Manu85 @sdetweil
                    @sdetweil fortunately I haven’t taken it yet, I’m starting well…and yes I will translate, thank you
                      sdetweil @Manu85
                      @Manu85 it’s ok, install again will not do it… checks and exits
                        Manu85 @sdetweil
                        @sdetweil ok, so I pass this line in putty
                        upgrade-script.sh
                        if so do I have to be in the MM folder or at the base of the pi?
                          Manu85 @sdetweil
                          @sdetweil if so do I have to be in the MM folder or at the base of the pi?
                            sdetweil @Manu85
                            it has to be the entire line. just push the copy icon that appears when your mouse is over the line in the GitHub content
                            the script figures it all out
                              Manu85 @sdetweil
                              @sdetweil This is the command:
                              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                sdetweil @Manu85
                                @Manu85 yes, that is the 1st test, test run
                                  Manu85 @sdetweil
                                  @sdetweil ok I do it
                                    Manu85 @sdetweil
                                    @sdetweil I say yes or no?
                                      sdetweil @Manu85
                                      @Manu85 well, you have 3 files of ours that will be changed
                                      main.css
                                      and weather.js and calendar.js
                                      those changes will be lost, unless you know what you changed and why…
                                      in general you NEVER edit any of our files…
                                      ALL config goes in config.js
                                      ALL css goes in custom.css
                                      reply no… also, I am adding a new check in test run mode…
                                      these changed files is the EXACT reason for test mode.
                                      otherwise those changes would be lost and your mirror might be broken
                                        Manu85 @sdetweil
                                        @sdetweil I may have moved something before meeting you, but in any case, I didn’t do anything that was important, now I know that I only touch config.js and css.custom!
                                        to carry out a test I pass the same line?
                                          sdetweil @Manu85
                                          you just DID the test pass…
                                          if you want to see what changed in those files , for each do
                                          git diff thefilename
                                          for example
                                          git diff css/main.css
                                            Manu85 @sdetweil
                                            @sdetweil I certainly didn’t understand…when I place the order I get this
                                            pi@MagicMirror:~ $ git diff css/main.css
                                            Not a git repository
                                            To compare two paths outside a working tree:
                                            usage: git diff [--no-index] <path> <path>
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
