    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.6m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil ok, so I pass this line in putty
      upgrade-script.sh
      if so do I have to be in the MM folder or at the base of the pi?
        Manu85 @sdetweil
        @sdetweil if so do I have to be in the MM folder or at the base of the pi?
          sdetweil @Manu85
          it has to be the entire line. just push the copy icon that appears when your mouse is over the line in the GitHub content
          the script figures it all out
            Manu85 @sdetweil
            @sdetweil This is the command:
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              sdetweil @Manu85
              @Manu85 yes, that is the 1st test, test run
                Manu85 @sdetweil
                @sdetweil ok I do it
                  Manu85 @sdetweil
                  @sdetweil I say yes or no?
                    sdetweil @Manu85
                    @Manu85 well, you have 3 files of ours that will be changed
                    main.css
                    and weather.js and calendar.js
                    those changes will be lost, unless you know what you changed and why…
                    in general you NEVER edit any of our files…
                    ALL config goes in config.js
                    ALL css goes in custom.css
                    reply no… also, I am adding a new check in test run mode…
                    these changed files is the EXACT reason for test mode.
                    otherwise those changes would be lost and your mirror might be broken
                      Manu85 @sdetweil
                      @sdetweil I may have moved something before meeting you, but in any case, I didn’t do anything that was important, now I know that I only touch config.js and css.custom!
                      to carry out a test I pass the same line?
                        sdetweil @Manu85
                        @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                        you just DID the test pass…
                        if you want to see what changed in those files , for each do
                        git diff thefilename
                        for example
                        git diff css/main.css
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 30
                        • 31
                        • 19 / 31
