Changing icons of the modules Current Weather and Weather Forecast
@sdetweil after a night’s sleep I think I understood…
@sdetweil following my last message I did:
pm2 stop alland then I made your script:
bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"then I went to the folder:
~/MagicMirror/installers/upgrade.logand I copied the last lines of:
"upgrade started"I don’t know if I did the right thing but I took the history of what you asked me to do
Upgrade started - ven. janv. 26 13:36:00 CET 2024 system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux doing test run = true, NO updates will be applied! the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster n (node version manager tool) not installed, doing test run, install skipped [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv18.18.0[0m [0mInstalled Node version: [1mv14.21.3[0m [96mNode should be upgraded.[0m [92mNode.js upgrade defered, doing test run[0m [96mCheck current NPM installation ...[0m [0mNPM currently installed. Checking version number. [0mMinimum npm version: [1mV9.8.1[0m [0mInstalled npm version: [1mV6.14.18[0m [96mnpm should be upgraded.[0m [96mnpm upgrade defered, doing test run ...[0m saving custom.css remote name = origin upgrading from version 2.23.0 to 2.26.0 fetching latest revisions git fetch rc=0 current branch = master On branch master Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded. (use "git pull" to update your local branch) Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git checkout -- <file>..." to discard changes in working directory) modified: css/main.css modified: fonts/package-lock.json modified: modules/default/calendar/calendar.js modified: modules/default/weather/weather.js modified: package-lock.json modified: vendor/package-lock.json Untracked files: (use "git add <file>..." to include in what will be committed) : { core css/icons/ css/save_custom.css howEnd: false, liceMultiDayEvents: false, modules/default/currentweather/ nohup.out tDaysCount: 0, "ter(\"calendar\", {mberOfDays: 365," no changes added to commit (use "git add" and/or "git commit -a") there are 6 local files that are different than the master repo css/main.css fonts/package-lock.json modules/default/calendar/calendar.js modules/default/weather/weather.js package-lock.json vendor/package-lock.json save/restore files selection = n restoring css/main.css from repo skipping restore for css/main.css, doing test run restoring fonts/package-lock.json from repo skipping restore for fonts/package-lock.json, doing test run restoring modules/default/calendar/calendar.js from repo skipping restore for modules/default/calendar/calendar.js, doing test run restoring modules/default/weather/weather.js from repo skipping restore for modules/default/weather/weather.js, doing test run restoring package-lock.json from repo skipping restore for package-lock.json, doing test run restoring vendor/package-lock.json from repo skipping restore for vendor/package-lock.json, doing test run test merge result rc='' , if empty, no conflicts skipping merge, only test run Checking for modules with removed libraries downloading dumpactivemodules script updating dependencies for active modules with package.json files processing for module MMM-SmartWebDisplay please wait ---------------------------------- skipped processing for MMM-SmartWebDisplay, doing test run processing complete for module MMM-SmartWebDisplay processing for module MMM-ISS-Live please wait ---------------------------------- skipped processing for MMM-ISS-Live, doing test run processing complete for module MMM-ISS-Live restoring custom.css removing git alias Upgrade ended - ven. janv. 26 13:36:17 CET 2024
@Manu85 but that is test mode, no changes.
and the changed mm files are still there
main.css…
I thought u restored the originals as you migrated the changes…
@Manu85 as I will be in the car all day,
make sure to stop mm before running the upgrade
pm2 stop all
I added code a few changes ago to detect and stop mm, but it appears not to be working for you
@sdetweil Thank you for your answer if I understand correctly for safety I do
pm2 stop all pi@MagicMirror:~/MagicMirror $ pm2 stop allafter that
bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" applythat’s it ? and should I pass this line to the root of the MM or in the MM folder
pi@MagicMirror:~$Or
pi@MagicMirror:~/MagicMirror $I’m waiting for your response before making a mistake
@Manu85 the current directory does not matter,
the script goes to it on its own -
@sdetweil ok, I’ll try it, I’ll let you know if everything went well…
@sdetweil I ran your update script, I don’t get an error message, are there any additional operations or do I reboot the pi?
@sdetweil hello, I did a reboot of the pi and… it restarted magic (like the mirror :-)) I have some small settings for which I cannot find solutions
For Weather:
the 1st: it’s the temperature which displays more than 280° C, I know that there is global warming but still…
the 2nd: the display of the weather forecast for the following days is a little confusing and I can’t find the settings in the console ctrl+shift+i and do you think I can write the sentence “Feels Like” in French?
for calendar:
I had put icons for each calendar in config.js, 1 for mine, 1 for my wife etc. ex: {symbol: 'male', url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpxxxxxxxxxxxxx' }, { symbol: 'birthday-cake', url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWxxxxxxxxxxx'in the custom css I had added color to each symbol to differentiate them (I saw that it was necessary to change .fa.fa in the custom css to .fas.fa) ex:
.fas.fa-male { color: #2B60DE; /* Dodger Blue */ } .fas.fa-birthday-cake { color: #ff0000; /* Red */ } .fas.fa-trash-o { color: #00FF00; /* Green */ }they all work except this one
symbol: 'trash-o',for this one I don’t have any symbol
@Manu85 trash-o is just fa.
you have .fas.fa
which means MUST HAVE BOTH on the same element
add a spacebut also maybe take .fas off
