    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil ```
      pi@MagicMirror:~ $ ~/MagicMirror/installers/upgrade.log
      -bash: /home/pi/MagicMirror/installers/upgrade.log: Permission non accord▒e
      pi@MagicMirror:~ $
        sdetweil @Manu85
        @Manu85 no. not execute . open and look at
        copy last few lines here
        M 1 Reply Last reply
          Manu85 @sdetweil
          @sdetweil I copied everything, if necessary
          Upgrade started - mer. janv. 24 17:51:10 CET 2024
          system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
          n (node version manager tool) not installed, doing test run, install skipped
          Minimum Node version: v18.18.0
          Installed Node version: v14.21.3
          Node should be upgraded.
          Node.js upgrade defered, doing test run
          Minimum npm version: V9.8.1
          Installed npm version: V6.14.18
          npm should be upgraded.
          npm upgrade defered, doing test run  ...
          saving custom.css
          remote name = origin
          upgrading from version 2.23.0 to 2.26.0
          fetching latest revisions
          git fetch rc=0
          current branch = master
          On branch master
          Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
            (use "git pull" to update your local branch)
            (use "git add <file>..." to update what will be committed)
            (use "git checkout -- <file>..." to discard changes in working directory)
          	modified:   css/main.css
          	modified:   fonts/package-lock.json
          	modified:   modules/default/calendar/calendar.js
          	modified:   modules/default/weather/weather.js
          	modified:   package-lock.json
          	modified:   vendor/package-lock.json
          Untracked files:
            (use "git add <file>..." to include in what will be committed)
          	core
          	css/icons/
          	css/save_custom.css
          	modules/default/currentweather/
          	nohup.out
          no changes added to commit (use "git add" and/or "git commit -a")
          there are 6 local files that are different than the master repo
             css/main.css
             package-lock.json
          save/restore files selection = n
          restoring css/main.css from repo
          skipping restore for css/main.css, doing test run
          restoring fonts/package-lock.json from repo
          skipping restore for fonts/package-lock.json, doing test run
          restoring modules/default/calendar/calendar.js from repo
          skipping restore for modules/default/calendar/calendar.js, doing test run
          restoring modules/default/weather/weather.js from repo
          skipping restore for modules/default/weather/weather.js, doing test run
          restoring package-lock.json from repo
          skipping restore for package-lock.json, doing test run
          restoring vendor/package-lock.json from repo
          skipping restore for vendor/package-lock.json, doing test run
          test merge result rc='' , if empty, no conflicts
          skipping merge, only test run
          downloading dumpactivemodules script
          updating dependencies for active modules with package.json files
          	processing for module MMM-OneCallWeather please wait
          	skipped processing for MMM-OneCallWeather, doing test run
          	processing complete for module MMM-OneCallWeather
          	processing for module MMM-SmartWebDisplay please wait
          	skipped processing for MMM-SmartWebDisplay, doing test run
          	processing complete for module MMM-SmartWebDisplay
          	processing for module MMM-ISS-Live please wait
          	skipped processing for MMM-ISS-Live, doing test run
          	processing complete for module MMM-ISS-Live
          restoring custom.css
          removing git alias
          Upgrade ended - mer. janv. 24 18:06:38 CET 2024
          Upgrade started - mer. janv. 24 20:51:08 CET 2024
          Upgrade started - mer. janv. 24 21:02:28 CET 2024
          Upgrade started - mer. janv. 24 21:26:35 CET 2024
          Upgrade started - mer. janv. 24 21:31:01 CET 2024
          Upgrade started - jeu. janv. 25 08:56:35 CET 2024
          Upgrade started - jeu. janv. 25 09:02:37 CET 2024
          Upgrade started - jeu. janv. 25 10:04:34 CET 2024
          A npm process is currently running. Can't upgrade.
          Please quit all npm processes and restart the installer.
          S 2 Replies Last reply
            sdetweil @Manu85
            @Manu85 you have your MagicMirror running from
            npm start
            right?
            you need to stop it, ctrl-c in that terminal window
            also show output of
            pm2 status
              sdetweil @Manu85
              @Manu85 I added a couple more fixes to the pm2 stop…
              tested here… give it a try again…
              I am busy most of the day… will try to check in when I can
              traveling tomorrow
              M M 3 Replies Last reply
                Manu85 @sdetweil
                @sdetweil sorry but I didn’t understand what to do, my MM is running, I don’t know if it’s running from
                npm start
                you say (you need to stop it, ctrl-c in that terminal window) in which terminal? do you have to press the “ctrl-c” keys on the keyboard? sorry for my stupid questions
                  manu85340 @sdetweil
                  @sdetweil I hadn’t seen your message… it’s not urgent and everyone has their own jobs, you’ll answer me when you can, have a good trip
                    Manu85 @sdetweil
                    @sdetweil after a night’s sleep I think I understood…
                      Manu85 @sdetweil
                      @sdetweil following my last message I did:
                      pm2 stop all
                      and then I made your script:
                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                      then I went to the folder:
                      and I copied the last lines of:
                      "upgrade started"
                      I don’t know if I did the right thing but I took the history of what you asked me to do
                      Upgrade started - ven. janv. 26 13:36:00 CET 2024
                      saving custom.css
                      git fetch rc=0
                      On branch master
                      Untracked files:
                      	core
                      	css/icons/
                      	css/save_custom.css
                      	howEnd: false,
                      	liceMultiDayEvents: false,
                      	nohup.out
                      	tDaysCount: 0,
                      	"ter(\"calendar\", {mberOfDays: 365,"
                         css/main.css
                         package-lock.json
                      removing git alias
                      Upgrade ended - ven. janv. 26 13:36:17 CET 2024
                        sdetweil @Manu85
                        @Manu85 but that is test mode, no changes.
                        and the changed mm files are still there
                        main.css…
                        I thought u restored the originals as you migrated the changes…
                          sdetweil @Manu85
                          @Manu85 as I will be in the car all day,
                          make sure to stop mm before running the upgrade
                          pm2 stop all
                          I added code a few changes ago to detect and stop mm, but it appears not to be working for you
                            Manu85 @sdetweil
                            @sdetweil Thank you for your answer if I understand correctly for safety I do
                            pm2 stop all
                            pi@MagicMirror:~/MagicMirror $ pm2 stop all
                            after that
                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                            that’s it ? and should I pass this line to the root of the MM or in the MM folder
                            pi@MagicMirror:~$
                            Or
                            I’m waiting for your response before making a mistake
                              sdetweil @Manu85
                              @Manu85 the current directory does not matter,
                              the script goes to it on its own
                                Manu85 @sdetweil
                                @sdetweil ok, I’ll try it, I’ll let you know if everything went well…
                                  Manu85 @sdetweil
                                  @sdetweil I ran your update script, I don’t get an error message, are there any additional operations or do I reboot the pi?
                                    Manu85 @sdetweil
                                    @sdetweil hello, I did a reboot of the pi and… it restarted magic (like the mirror :-)) I have some small settings for which I cannot find solutions
                                    For Weather:
                                    the 1st: it’s the temperature which displays more than 280° C, I know that there is global warming but still…
                                    the 2nd: the display of the weather forecast for the following days is a little confusing and I can’t find the settings in the console ctrl+shift+i and do you think I can write the sentence “Feels Like” in French?
                                    for calendar:
                                    I had put icons for each calendar in config.js, 1 for mine, 1 for my wife etc. ex: {
                                    symbol: 'male',
                                    url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpxxxxxxxxxxxxx'
                                    symbol: 'birthday-cake',
                                    url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWxxxxxxxxxxx'
                                    in the custom css I had added color to each symbol to differentiate them (I saw that it was necessary to change .fa.fa in the custom css to .fas.fa) ex:
                                    .fas.fa-male {
                                       color: #2B60DE; /* Dodger Blue */
                                    .fas.fa-birthday-cake {
                                       color: #ff0000; /* Red */
                                    .fas.fa-trash-o {
                                       color: #00FF00; /* Green */
                                    they all work except this one
                                    symbol: 'trash-o',
                                    for this one I don’t have any symbol
                                      sdetweil @Manu85
                                      @Manu85 trash-o is just fa.
                                      you have .fas.fa
                                      which means MUST HAVE BOTH on the same element
                                      add a space
                                      but also maybe take .fas off
                                        sdetweil @Manu85
                                        @Manu85 you just restart mm…(pm2 restart MagicMirror)
                                        any how, on the weather
                                        I think you have a conflict on how the API reports and what the module thinks it is
                                        I think the API is reporting in Fahrenheit, but the code thinks in Celsius
                                        see config options
                                          sdetweil @Manu85
                                          @Manu85 of, feels like…
                                          see the translations/fr.json
                                          its precip
                                          percent possibility of precipitation, (rain.snow)
                                          chance of rain or snow
                                          some languages don’t have a term for that
                                          I think you could change it to blank " "
                                          but , then this will be a file to watch out for on future upgrades
                                            Manu85 @sdetweil
                                            @sdetweil ok, thank you for this information, I will try to resolve one by one, to
                                            symbol: 'trash-o',
                                            I tried all your suggestions and I still have the same result, what is strange is that for the other icons ex:
                                            I do have a birthday cake
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
