    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil another example that bothers me
        Manu85 @sdetweil
        @sdetweil one last one for which I don’t know what to do either, thank you again for your help
          sdetweil @Manu85
          @Manu85 not the -lock.json files , these are generated by npm install
          the MagicMirror thing is inside a comment, so not important.
          the default symbol, the green goes in config.js for the calendar module. don’t worry about the red
            Manu85 @sdetweil
            @sdetweil ok, thank you for your answers, I’m going to do the weather.js and according to what you tell me I’m going to leave aside the 2 lock.json and then I’ll stop for this evening my brain is upside down , have a good day…and see you tomorrow if you want to continue helping me
              Manu85 @sdetweil
              @sdetweil I’m still here, I made the modifications in css main and js.config I placed the command:
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              here is what I have
              pi@MagicMirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              Minimum Node version: v18.18.0
              Installed Node version: v14.21.3
              Node should be upgraded.
              pi@MagicMirror:~ $
                sdetweil @Manu85
                @Manu85 well…let me check when I get home. maybe 30 mins from now 1800 my time US central
                  sdetweil @Manu85
                  @Manu85 fixed, run again
                    Manu85 @sdetweil
                    @sdetweil hello, I rebotted the pi and ran the command again
                    and I have the impression that it remains stuck in the same place the cursor does not display:
                    pi@MagicMirror:~ $
                      sdetweil @Manu85
                      @Manu85 can you post the last part of
                      ~/MagicMirror/installers/upgrade.log
                      from the last
                      "upgrade started"
                        Manu85 @sdetweil
                        @sdetweil ```
                        pi@MagicMirror:~ $ ~/MagicMirror/installers/upgrade.log
                        -bash: /home/pi/MagicMirror/installers/upgrade.log: Permission non accord▒e
                        pi@MagicMirror:~ $
                          sdetweil @Manu85
                          @Manu85 no. not execute . open and look at
                          copy last few lines here
                            Manu85 @sdetweil
                            @sdetweil I copied everything, if necessary
                            Upgrade started - mer. janv. 24 17:51:10 CET 2024
                            system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                            n (node version manager tool) not installed, doing test run, install skipped
                            Node.js upgrade defered, doing test run
                            Minimum npm version: V9.8.1
                            Installed npm version: V6.14.18
                            npm should be upgraded.
                            npm upgrade defered, doing test run  ...
                            saving custom.css
                            remote name = origin
                            upgrading from version 2.23.0 to 2.26.0
                            fetching latest revisions
                            git fetch rc=0
                            current branch = master
                            On branch master
                            Your branch is behind 'origin/master' by 213 commits, and can be fast-forwarded.
                              (use "git pull" to update your local branch)
                              (use "git add <file>..." to update what will be committed)
                              (use "git checkout -- <file>..." to discard changes in working directory)
                            	modified:   css/main.css
                            	modified:   fonts/package-lock.json
                            	modified:   modules/default/calendar/calendar.js
                            	modified:   modules/default/weather/weather.js
                            	modified:   package-lock.json
                            	modified:   vendor/package-lock.json
                            Untracked files:
                              (use "git add <file>..." to include in what will be committed)
                            	core
                            	css/icons/
                            	css/save_custom.css
                            	modules/default/currentweather/
                            	nohup.out
                            no changes added to commit (use "git add" and/or "git commit -a")
                            there are 6 local files that are different than the master repo
                               css/main.css
                               package-lock.json
                            save/restore files selection = n
                            restoring css/main.css from repo
                            skipping restore for css/main.css, doing test run
                            restoring fonts/package-lock.json from repo
                            skipping restore for fonts/package-lock.json, doing test run
                            restoring modules/default/calendar/calendar.js from repo
                            skipping restore for modules/default/calendar/calendar.js, doing test run
                            restoring modules/default/weather/weather.js from repo
                            skipping restore for modules/default/weather/weather.js, doing test run
                            restoring package-lock.json from repo
                            skipping restore for package-lock.json, doing test run
                            restoring vendor/package-lock.json from repo
                            skipping restore for vendor/package-lock.json, doing test run
                            test merge result rc='' , if empty, no conflicts
                            skipping merge, only test run
                            downloading dumpactivemodules script
                            updating dependencies for active modules with package.json files
                            	processing for module MMM-OneCallWeather please wait
                            	skipped processing for MMM-OneCallWeather, doing test run
                            	processing complete for module MMM-OneCallWeather
                            	processing for module MMM-SmartWebDisplay please wait
                            	skipped processing for MMM-SmartWebDisplay, doing test run
                            	processing complete for module MMM-SmartWebDisplay
                            	processing for module MMM-ISS-Live please wait
                            	skipped processing for MMM-ISS-Live, doing test run
                            	processing complete for module MMM-ISS-Live
                            restoring custom.css
                            removing git alias
                            Upgrade ended - mer. janv. 24 18:06:38 CET 2024
                            Upgrade started - mer. janv. 24 20:51:08 CET 2024
                            Upgrade started - mer. janv. 24 21:02:28 CET 2024
                            Upgrade started - mer. janv. 24 21:26:35 CET 2024
                            Upgrade started - mer. janv. 24 21:31:01 CET 2024
                            Upgrade started - jeu. janv. 25 08:56:35 CET 2024
                            Upgrade started - jeu. janv. 25 09:02:37 CET 2024
                            Upgrade started - jeu. janv. 25 10:04:34 CET 2024
                            A npm process is currently running. Can't upgrade.
                            Please quit all npm processes and restart the installer.
                              sdetweil @Manu85
                              @Manu85 you have your MagicMirror running from
                              npm start
                              right?
                              you need to stop it, ctrl-c in that terminal window
                              also show output of
                              pm2 status
                                sdetweil @Manu85
                                @Manu85 I added a couple more fixes to the pm2 stop…
                                tested here… give it a try again…
                                I am busy most of the day… will try to check in when I can
                                traveling tomorrow
                                M M 3 Replies Last reply Reply Quote 0
                                  Manu85 @sdetweil
                                  @sdetweil sorry but I didn’t understand what to do, my MM is running, I don’t know if it’s running from
                                  npm start
                                  you say (you need to stop it, ctrl-c in that terminal window) in which terminal? do you have to press the “ctrl-c” keys on the keyboard? sorry for my stupid questions
                                    manu85340 @sdetweil
                                    @sdetweil I hadn’t seen your message… it’s not urgent and everyone has their own jobs, you’ll answer me when you can, have a good trip
                                      Manu85 @sdetweil
                                      @sdetweil after a night’s sleep I think I understood…
                                        Manu85 @sdetweil
                                        @sdetweil following my last message I did:
                                        pm2 stop all
                                        and then I made your script:
                                        then I went to the folder:
                                        and I copied the last lines of:
                                        "upgrade started"
                                        I don’t know if I did the right thing but I took the history of what you asked me to do
                                        Upgrade started - ven. janv. 26 13:36:00 CET 2024
                                        saving custom.css
                                        git fetch rc=0
                                        On branch master
                                        Untracked files:
                                        	core
                                        	css/icons/
                                        	css/save_custom.css
                                        	howEnd: false,
                                        	liceMultiDayEvents: false,
                                        	nohup.out
                                        	tDaysCount: 0,
                                        	"ter(\"calendar\", {mberOfDays: 365,"
                                           css/main.css
                                           package-lock.json
                                        removing git alias
                                        Upgrade ended - ven. janv. 26 13:36:17 CET 2024
                                          sdetweil @Manu85
                                          @Manu85 but that is test mode, no changes.
                                          and the changed mm files are still there
                                          main.css…
                                          I thought u restored the originals as you migrated the changes…
                                            sdetweil @Manu85
                                            @Manu85 as I will be in the car all day,
                                            make sure to stop mm before running the upgrade
                                            pm2 stop all
                                            I added code a few changes ago to detect and stop mm, but it appears not to be working for you
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
